Old 17th Oct 2025, 7:52 pm   #1
LA9CHA Thorvald
Default GM2890 service manual.
Hello, anyone who may have a copy of Philips GM2890 FM signal generator , in pdf format, service manual or user manual?
Hope for the best : Thorvald
LA9CHA Thorvald is offline   Reply With Quote
Old 17th Oct 2025, 10:29 pm   #2
karesz*
Default Re: GM2890 service manual.
Hi Thorwald,
you can find a short version here: radiomuseum.org/r/philips_fm_messgenerator_gm2890.html
karesz* is offline   Reply With Quote
Old 17th Oct 2025, 10:38 pm   #3
karesz*
Hi Thorwald,
Than a better quality schematics here https://elektrotanya.com/philips_gm2890_sch.pdf/download.html#google_vignette
Old 19th Oct 2025, 7:06 pm   #4
LA9CHA Thorvald
Hello kaesz and many thanks for answer. I already have checked up Elektrotanya, but only circuit diagram was available. Regarding the other adress, I have tryed several times but for some reason the payment for loading down a copy was denied. Due you know if the manual is ok for pdf download??Kind rgs: Thorvald
Old 19th Oct 2025, 11:27 pm   #5
Julesomega
Julesomega's Avatar
If you are logged in to radiomuseum you should be able to download the 3 pages of the manual. I just tried and had to hit the button marked ID = 138774 to enable the images to be enlarged.
If you can't download them, email me and I can send them over.
- Julian
It's good here
Julesomega is offline   Reply With Quote
Old 20th Oct 2025, 7:15 am   #6
LA9CHA Thorvald
Hello again Julian, if possible could you kindly e-mail me the pages!
Old 20th Oct 2025, 12:54 pm   #7
karesz*
Dear Thorvald,
you have to click on the selected site to download it, i.e.; www.radiomuseum.org/dsp_guest_schema_register-ng.cfm?schaltplan_id=51134
Than answer if you are a robot, give your emails data.
From your received doc (3x /24hours and max 10 in 30 days if you don't have membership-that cost €20, but only one time), on te second pdf site you can see the wished documentation, not a rocket technik ...
Old 3rd Nov 2025, 11:03 am   #8
LA9CHA Thorvald
Default GM2890 service or user manual.
Hello, searching for service or user manual for Philips GM2890 FM signal generator.
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
Copyright ©2002 - 2025, Paul Stenning.
