Old 24th Dec 2023, 12:40 pm   #141
GMB
GMB's Avatar
Default Re: Mullard Valve Tester Card Project
I am surprised that you have seen it as not issued as it seems to be quite common.
GMB is offline   Reply With Quote
Old 24th Dec 2023, 4:45 pm   #142
Ed_Dinning
Hi George,thanks for the info, it must be my listing. It also lists the 680 card as suitable
Cheers, Ed
Old 8th Aug 2024, 2:05 pm   #143
theredhouseinn
theredhouseinn's Avatar
Hi folks.
I am back on the job of making missing cards for my collection.
I have a complete set up to 600 apart from 87 & 374.
In the 600 range I am missing no's - 603,604,605,608,609,610,611,612,613,614,615,617,618,621,622,623,624,625,626,627,628,629,662,667,675, 676,677,678,679,680,681,682,684,685,686,687,688,689,690,692,694,695,696,697,698, & 699.
In the 700 range I am missing no's -
700,701,702,703,704,705C,722,723,724,725,726,727,728,729,730,731,732,733,734,736,738,739,742,743,744 ,745,746,748,749,751,752,763,765,777,779,780,783,785,786,797,798, & 799.
In the 800 range I am missing no's -
802,805,806,807,809,810,811,812,813,814,815,816,819,820,821,822,823,826,827,828,829,831,832,833,834, 835,836,837,838,839,840,841,843,844,845,846,848,849,851,852,853,855,856,858,859,863,864,865,866,867, 868,869,870,871,872,873,874,875,876,877,879,880,882,883,884,889,890,894,895, & 897.
That will do for now. If anyone can help me with pdf templates for these cards it will be very appreciated. I will get on to the rest when I have hopefully made these.
Many thanks
John.
theredhouseinn is offline   Reply With Quote
Old 29th Sep 2024, 3:22 pm   #144
DavidM0ICZ
Here is my card punch, and how it was made and used.
ID:	304283Click image for larger version
ID:	304285Click image for larger version
I cut two 6mm mild steel card shapes. I drilled all holes 9/32" and taper reamed them so the punch enters, and the cut paxolin discs exit, easily.
Five clips hold the plates together with the blank card between. This leaves space to carve the side cutout of the paxolin blank, and chamfer the corners, using the plates as a jig.
The card edges were filed to shape, tested for fit in the machine, and smoothed with sandpaper.
The punch is 9/32" silver steel, hardened, and tempered purple. The drilling machine is used as a press to punch the holes in the blank cards (with the spindle not revolving!).
The card blanks were cut from Presspahn 150 SRPB (P1 Paxolin) 0.8mm sheet. A 1220x1220mm sheet will yield 53 blanks, barring mistakes!
The material is somewhat brittle but I found it will cut by scoring and snapping, or by treadle guillotine. The edges can be sharp, especially after snapping, and needed thorough smoothing with a sanding block.
I have only punched a few cards so far, but it seems to work well enough.
David.
DavidM0ICZ is offline   Reply With Quote
Old 3rd Dec 2024, 10:52 am   #145
theredhouseinn
Hi Folks.
Does anyone have the hole details for an EL506 pentode. It is not listed on the MHSVT chart.
I see from the Valve museum website that it is a replacement for the 7868 USA type used in guitar, and hi fi amps.. (Fisher X-100B).
John.
Old 3rd Dec 2024, 2:00 pm   #146
GMB
GMB's Avatar
Sadly neither of those valves are in any Mullard list I have seen for the MHSVT.
Perhaps someone can find an almost-equivalent?
Old 3rd Dec 2024, 4:13 pm   #147
theredhouseinn
The nearest valve data I can find to match the 9868 it the KT66 which I have a card for.
I have ordered a B9D valve base to make an adaptor using an old octal valve plug from a defunct valve.
There is an adaptor no. 10 in the MHSVT kit but the internal connections do not fit the KT66.
Does anyone have any other ideas?
John.
Old 6th Dec 2024, 4:51 pm   #148
theredhouseinn
Hi folks.
I have made up the adaptor, and using a new 7868, the KT66 card barely lifted the spot off the red line. Next I tried 6V6 card and this was much better, lifting the spot into the top of the yellow band. I will stick with this for the time being. Of the 4 7868's in the amp 3 are showing electrode faults, 1 good one.
There are quite a lot of output valves with same pin connections, so I may try a few more when I have time.
John.
Old 21st Oct 2025, 11:47 am   #149
DavidM0ICZ
Card 282B
I have a card labelled 282B. Other than the label, it appears to be the same as card 382B for the Mazda UU7 f.w. rectifier. Card 282 is a single card for the Brimar 8D2 h.f. pentode.
Could it have been wrongly-printed at the factory?
David.
ID:	320482   Click image for larger version
ID:	320483   Click image for larger version
Old 21st Oct 2025, 1:28 pm   #150
GMB
GMB's Avatar
There is no doubt that your card marked 282B is actually a 382B card.
The 282 (single) card is different as your post indicates.
So it seems they printed the wrong number on the card. Rather surprising.
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
Copyright ©2002 - 2025, Paul Stenning.
