25th Aug 2021, 6:16 pm | #441 |
Re: Ortonview PCB
Ah! I didn't catch that. Maybe NENIN and XCLOCK do need syncing somehow.
25th Aug 2021, 6:23 pm | #442 | |
Re: Ortonview PCB
The capacitors were ultimately Mark's suggestion but the idea may have come from your original observation that hanging something on those lines made the fault go away, plus my own (much earlier) experience of having 'fixed' a computer fault which went away when a scope probe was put on a particular pin, by soldering a 1M resistor and 50pF capacitor from the pin to 0V (To make the pin 'think' it had a scope connected to it). |
25th Aug 2021, 6:24 pm | #443 |
Re: Ortonview PCB
Well I've just received some 74LS74's and found a few other spare gates so I might be able to do some experiments tomorrow. looks like its proto-board time!
Now I am wishing I'd made the top corner of the board a prototyping area after all |
25th Aug 2021, 6:26 pm | #444 |
Re: Ortonview PCB
It kind of already is, just lop a few of the existing interconnecting tracks... power pins will still be in the right place.
25th Aug 2021, 6:34 pm | #445 | ||
Re: Ortonview PCB
25th Aug 2021, 7:09 pm | #446 |
Re: Ortonview PCB
I think adding the 74ls74 as described in #275, possibly also connect NENIN from PIC to clear on the 74ls74 so that when NENIN goes low there is not so much of a delay in NENIN going low to the 8060. This would also add a little setup time from NENIN going high prior to rising edge of the clock.
I’m hoping there is no need to fine tune the delay of NENIN to the 8060 with any RC delay. Pure guesswork but suspect there is a setup time inside the 8060 for NENIN high to the rising edge of xout, or its internal equivalent, and the setup time might be different for the address and NWDS control. Registering NENIN to xout should give maximum set up time to the next rising edge so that both the address control and the NWDS control are triggered on the same clock cycle. Suspect Slothie might beat me to it, but I’ll also try adding a 74ls74 on protoboard. |
25th Aug 2021, 7:21 pm | #447 |
Re: Ortonview PCB
The other thing I noticed yesterday is that the address lines are not pulled high to give good high logic level. It might be good to add pull up resistors, though that would make the corrupted write issue worse. Maybe if adding the 74ls74 works we can see if it still works with pull up resistors, that should make it worst case for the corrupted write issue.
25th Aug 2021, 7:22 pm | #448 |
Re: Ortonview PCB
Well if it does work then it would explain why its so random and it varies over time.
25th Aug 2021, 7:29 pm | #449 | |
Re: Ortonview PCB
25th Aug 2021, 8:23 pm | #450 | ||
Re: Ortonview PCB
8060 doesn’t drive the outputs very high, I guess that should be expected for nmos. |
28th Aug 2021, 1:06 am | #451 |
Re: Ortonview PCB
I connected a 74hct74 as in #446, so synch the rising edge of NENIN to rising edge of Xout, but with no improvement. If anything it is now more repeatable.
I think next attempt is to synch to the falling edge of clock. |
28th Aug 2021, 8:14 am | #452 |
Re: Ortonview PCB
Keep up the good work, Mark. This problem will fall eventually, as long as we keep hacking away at it.
28th Aug 2021, 9:00 am | #453 | |
Re: Ortonview PCB
https://youtu.be/Zwh369ewhzc |
28th Aug 2021, 9:09 am | #454 |
Re: Ortonview PCB
I notice you still have the buffers installed - my problems, although undoubtedly exaggerated by having no power supply to the 6116(!!) seemed a lot worse when the buffers were installed, I had rows of characters rolling at that point.
I would suggest simplifying it to the 'no buffer' arrangement while trying these other tweaks - I think that's probably how Mark has his configured at the moment anyway. |
28th Aug 2021, 9:24 am | #455 | |
Re: Ortonview PCB
28th Aug 2021, 10:48 am | #456 |
Re: Ortonview PCB
just tried taking out the buffers and installing the links and it doesn't make a difference. Sorting through my chips for something I can use as an inverter now!
28th Aug 2021, 12:10 pm | #457 |
Re: Ortonview PCB
Inverted XOUT with a 74HCT02 NOR gate and it doesn't appear to have made a difference.
28th Aug 2021, 5:52 pm | #458 |
Re: Ortonview PCB
I don’t have the buffers fitted and no capacitors on the address lines.
I was using a tight loop using ILD on B10, This gives unwanted writes to both F10 and also B30, and I can see the early rise of both A10 and A5 on the scope. Also I can see the NENIN is definitely rising on the rising edge of xout, so the synch to xout was working. I was going to try the second half of the 74hct74 as an inverter, input to preset, output from Q and all other inputs grounded. As Slothie already tried an inverter without success I’ll skip that. Next attempt is RC from Q output of 74hct74 to clock second half of 74hct74. D and preset held high and clear to PIC NENIN. I think a 100pF cap and a 5k preset should give me a 0 to 250ns range. |
28th Aug 2021, 6:27 pm | #459 | |
Re: Ortonview PCB
I was wondering if we could use the rising edge of NADS to gate NENIN, as every read/write operation is always preceded by NADS, the downsides to this is that it is an ugly kludge, and that executing DLY statements would probably break it, as I don't beleive the SC/MP processes any memory cycles during a DLY. Also the original board didn't need NADS, so we shouldnt need it. I get the feeling that our friends at SoC might have had to do some "fine tuning" of their circuit to get it to work. It seems to me it is using NENIN in a way it wasn't intended to be used, ignoring NENOUT and NBREQ. Although you shouldn't be able to break the system by just asserting NENIN at an inopportune moment. |
28th Aug 2021, 6:28 pm | #460 |
Re: Ortonview PCB
Oh for the record, I am operating at 4.433619Mhz with no capacitors and no buffers. Firmware #692.
