Old 8th Jan 2018, 7:02 pm   #1
high_vacuum_house
high_vacuum_house's Avatar
Smile AVO valve tester MK.2 Mains setup problems
Good afternoon,
I have recently bought a MK.2 AVO valve characteristic tester. I am having difficulty in getting the mains setup working.
I have set it to check C and to electrode leakage ~ but on using the set ~ control I cannot get the needle into the red line. It is roughly 3/4" over this. The mains links are in the 240-250V position. I can bring it down to the line using a variac though the mains is now at
I think the meter circuit is to blame as bringing the mains down to the meter red line the heater set at 6V reads just over 4 volts AC. Using the variac to increase the mains voltage until the correct heater voltage is reached the mains is back at 230V though the needle is then way over the line.
What is the correct way of going about sorting out this issue without wrongly adjusting things and making the calibration for another part of the tester worse. I notice there are 2 big waxies inside each side of the meter and another capacitor on top of a transformer. Should I replace these at this stage.
Many thanks,
Christopher Capener
Interests in the collection and restoration of Tefifon players and 405 line television
high_vacuum_house is online now
Old 8th Jan 2018, 7:56 pm   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: AVO valve tester MK.2 Mains setup problems
Wax caps of this age are certainly suspect.
HamishBoxer is online now
Old 8th Jan 2018, 8:51 pm   #3
Ed_Dinning
Hi Chris, there is a huge thread on this in the forum. Basically there are quite a few caps that can go leaky, but there are also high stab tight tolerance resistors that may have drifted. All this in a system that is meant to keep the tester "standardised".
A bit of a test and change job I'm afraid, but they are good testers when sorted.
Ed
Ed_Dinning is online now
Old 8th Jan 2018, 9:59 pm   #4
G1RAO keith
Hi Chris
Change the wax caps by all means but there is a preset resistor marked (S) on the right hand side of the tester on the transformer assembly that is across the meter and is used as part of the set up procedure this may need adjustment along with the other two one marked GM and the other VG ,there should be some info in the threads mentioned by Ed.regards Keith.
G1RAO keith is offline
Old 9th Jan 2018, 10:41 am   #5
Kevin Hoyland
Morning Chris.
After last winter i went in to my work shop and had the same problem as you have with my Avo mk2 Valve Tester. To get it back working right I Had to replace the 16K9 Selenium Rectifer and KG1 with Philips soft -recovery Diodes type (BYW96E).The 16K9 had a split in it at one end. Then I cleaned the pins on the EA50 .At the side of the Diodes is a 125K Resistor this is for adjusting the meter my resistor was way out so I had to replace it. Then I replaced all the resistors on the roller switch. I then replaced all the 8uf and 0.05 Capacitors With new ones. Then cleaned all switches with Deoxit D5 cleaner After this the mk2 was back working as good as new. I then did the Avo Calibration on it.
Kevin
ID:	155201   Click image for larger version
ID:	155202   Click image for larger version
Kevin Hoyland is offline
Old 9th Jan 2018, 5:39 pm   #6
high_vacuum_house
Many thanks for your reply,
I have ordered some soft recovery diodes and have some 0.05uF capacitors here. I will go through the resistors to see if any are out of spec.
Christopher Capener
