Old 3rd Apr 2018, 6:37 pm   #1
rsedwards1
Default Unknown but working
Anyone know what this unit is? it aperars to be working thought it was a signal generator at first , but it has scale reading in ohms and micofarads mabe a capacitor tester the magic eye valve is working and the output terminals shows a sine wave varable . Had this over 30 years been in the garden shed , amazing it seams to work what ever it is.
ID:	160447   Click image for larger version
ID:	160448   Click image for larger version
ID:	160449   Click image for larger version
rsedwards1 is offline
Old 3rd Apr 2018, 6:47 pm   #2
llama
llama's Avatar
Default Re: Unknown but working
I imagine it's a resistor and capacitor measuring bridge. An oscillator in there would be the input to the bridge and the magic eye would be across the bridge to identify the null.
Graham
llama is offline
Old 3rd Apr 2018, 7:59 pm   #3
Ed_Dinning
It looks like a piece of home brew kit built into some ex-gov case.
There were several designs associated with PW, Radio constructor etc in the 50's.
If you know the valves it may be possible to trace its origins from there.
Ed
Ed_Dinning is offline
Old 3rd Apr 2018, 8:15 pm   #4
The Philpott
The Philpott's Avatar
Certainly is a bitzer- Belling Lee terminals and Paignton (Paynton?) knobs, and the indicator light and connectors look MOD origin. I bet you won't ever see another one..
The Philpott is offline
Old 3rd Apr 2018, 8:56 pm   #5
Sideband
Sideband's Avatar
Definitely home-brew. The scale gives it away as everything is hand-written. Yes it would be interesting to try and find the design so perhaps try to identify the valves used. Probably dates to the 50's when lots of Army Surplus gear was available.
Sideband is offline
Old 3rd Apr 2018, 9:33 pm   #6
rsedwards1
Graham
I think you are right , i put a capacitor acreoss the terminals and the magic eye closed off to about half . The Valves have typical WD ^ markings on them not checked the part numbers
Old 3rd Apr 2018, 10:33 pm   #7
Refugee
Refugee's Avatar
It does look like an AC R/C bridge.
I have got a Phillips factory made one that just does resistance but with an external decade box will also do capacitance.
It has been superseded by a very posh Marconi one that I recently restored.
Refugee is online now
