24th Jan 2020, 12:28 am | #1 |
US outlet query.
Just another daft question. Why is the right hand slot ('live' or 'hot') on an American 110 volts socket outlet sometimes 'T' shaped? I've seen them at airports and in commercial premises, but less so in domestic situations. I know that there is a 220 volt version with horizontal slots, and the usual 110 volt ones have vertical slots, but I'm curious about the T' slot. Cheers, Pete.
24th Jan 2020, 12:40 am | #2 |
Re: US outlet query.
Is this what you are looking for?
https://www.plugsocketmuseum.nl/NorthAm1combi.html |
24th Jan 2020, 12:53 am | #3 | |
The T shape is usually used in places like Hospitals to indicate the ground. Domestic outlets are the usual 3 pin and they are also much cheaper, and sometimes they are not always wired correctly.
David |
24th Jan 2020, 2:07 am | #4 |
It may be a standard 120 volt 20 amp outlet, rather than the much more common 120 volt 15 amp outlet.
Common USA practice is to connect multiple 15 amp outlets to 15 amp or to 20 amp circuits. If higher loading appliances are to be used, then 20 amp outlets on 20 amp circuits. The very common 15 amp plugs will fit 15 amp outlets or 20 amp outlets. The less common 20amp plugs will only fit the 20 amp outlets, a 15 amp outlet will reject the 20 amp plug. https://www.pinterest.com/pin/390265123937218008/ |
24th Jan 2020, 7:17 pm | #5 | |
I couldn't have answered the inquiry any better and I was in the trade. Dave, USradcoll1, retired electrician. |
