Old 1st Oct 2006, 7:06 pm   #1
ekcobeach
ekcobeach's Avatar
Default Removal of stubborn push-on knobs.
Hi All, Went to the local boot sale this morning and picked up two Hacker Sovereigns.One works well on all bands but the other only on VHF.I intend to strip both and use all of the good bits to make one good one.There are signs on one radio that someone has attempted to prize off the two largest knobs and they have buckled the brights.The bass and tone pulled off easily,is there a trick to removing the larger ones and is there anything else i need to know about before i attempt to strip them down.I know absolutely nothing about these types of radio so any info will be gratefully received. Regards to all, Colin.
ekcobeach is offline
Old 1st Oct 2006, 7:41 pm   #2
Paul_RK
Paul_RK's Avatar
Default Re: Hacker Sovereign 2.Help needed.
Hi Colin,
If there's a special trick to removing the volume and tuning knobs I've yet to find it. Most often I find they'll come off by just gripping the plastic and pulling, which is safest if you can do it as there's no need to touch the aluminium skirt. Otherwise, it's the usual tactic of a thin piece of cloth wrapped round a time and a half under the knob and pulled: I don't think I've ever caused any serious distortion to the skirt that way.
Paul
Paul_RK is online now
Old 15th Oct 2006, 4:51 pm   #3
Superhet Si
Superhet Si's Avatar
Turn the radio upside down and spray the pot shaft with WD40. leave over night and then heat the knob with a hairdryer. Should come off then!
My Youtube channel https://www.youtube.com/user/simonspiers
Superhet Si is offline
Old 15th Oct 2006, 6:55 pm   #4
howard
howard's Avatar
Hello,
I get Hacker knobs off using two forks or fork handles. I push the forks right under the knob, (not under the skirt) one either side, and gently rock and they soon come off. Obviously one has to be careful not to apply to much pressure on the perspex dial but I haven't cracked one yet ! Here's a pic of a Hacker Sovereign II acquired today with forks in action. As you can see, no damage to knob or perspex, it took under 30 seconds, and judging by the amount of dust under it, it hasn't been off for the best part of 40 years.
Howard
ID:	6178   Click image for larger version
howard is offline
Old 16th Oct 2006, 7:25 am   #5
Mike Phelan
Mike Phelan's Avatar
Quite often the reason for knobs being difficult to remove is the fact that the spindle and steel knob clips have corroded together - using WD40 or penetrating oil (if OK with plastics) will eventually shift them.
Colin
Sounds like an excellent car boot sale!
Howard
Four candles?
Mike.
Mike Phelan is offline
Old 16th Oct 2006, 9:40 am   #6
Paul_RK
Paul_RK's Avatar
Yes - my main caveat with a Hacker would be the possible effect of solvent oils on the back of the control panel and, when it came to the tuning knob, the likelihood of their getting on to the drive cord and doing no good. WD40 in particular, in my experience, seems to have a way of getting everywhere when sprayed, so most of the time if I use it at all I spray a little on the back of a spatula (OK, a screwdriver ) and drip it on to where it's needed.
My fears for the panel may be perfectly groundless: I've just yet to try the experiment of applying WD40 (or whatever) and watching for any effects. I must have removed comfortably over 50 of these particular volume and tuning knobs without ever needing anything beyond the wrapped cloth treatment.
Paul
Old 16th Oct 2006, 10:43 am   #7
ekcobeach
ekcobeach's Avatar
Default Re: Hacker Sovereign 2. Help needed.
Hi All, Thanks for all of your suggestions. On the radio in question, the knobs were so close to the dial that it was almost impossible to get anything under or around them. I found a strong piece of ribbon fabric which is very thin and it slipped under the knobs. I wound it once around the shaft, pulled hard, and hey presto the knob/s flew off!
