25th Jul 2020, 10:34 am | #1 |
Circa 1970 tape machines: low-speed modes
I've just managed to recover some old recordings from a tiny tape (3 inch?) which contains thin (double-play?) tape. I can only replay down to 3.75ips and there was some "chipmunk" stuff so I recorded the entire content to a digital recorder at 48kHz sampling, then re-sampled to recover the content. Much of it was recorded at 15/16th ips!! How common was this speed?? Perhaps Dictaphone applications?
John |
25th Jul 2020, 10:39 am | #2 | |
Re: Circa 1970 tape machines: low-speed modes
25th Jul 2020, 10:49 am | #3 |
I seem to remember a version of the Brenell deck with the 15/16 ips speed option. Brenell gave a very impressive demostration of Piano music recorded at this speed and (even better) at 1 7/8 ips at one of the very early Hi Fi Shows at the Russell Hotel in Russell Suqare, London.
THINKS: I wonder how many of you remember those early Shows?
Edward. |
25th Jul 2020, 10:53 am | #4 |
7.5/3.75/1.875 were probably the most common domestic speeds but some domestic and professional machines carried the slower speed. I know Philips, Uher, Akai, Sony and Revox made models with this speed, as did Nagra.
Because of its lower sound quality it was a tradeoff mainly used for either the smaller machines where recording time was limited, or on large reels for super long recording times. A standard format for logging radio broadcasts to satisfy legal requirements was 15/16ips on 10.5" reels of 1/4" tapes. With LP tape that gave a comfortable 12 hours per reel. It was also used on cassettes and the US Library of Congress developed it as a Talking Book standard using 4 tracks to give over 6 hours of programme on one Compact Cassette. The earlier British Clarke and Smith Talking Book tape cartridge (1/4" tape) also ran at 15/16 ips, giving over 13 hours on 6 tracks. That was often enough to contain narration of a complete novel. It's also the same tape speed used on standard VHS cassettes, allowing a little over 3 hours. When it was set up properly it could give quite reasonable fidelity especially as VHS cassettes used Chrome type tape. Last edited by TIMTAPE; 25th Jul 2020 at 11:07 am. |
25th Jul 2020, 11:06 am | #5 |
I believe 15/16 ips was the normal/default tape speed on most dictation machines and as stated above was sometimes the fourth (slowest) tape speed on some of the better reel to reel machines.
25th Jul 2020, 11:14 am | #6 |
Maybe on some but many Grundig and Philips dictation machines (1/4" and cassette width tape) were rim drive so as the take up reel filled up, tape speed increased. The capstan and pinch rollerless rim drive was simpler and more rugged, so more suited to constant starts, stops, rewinds etc in a dictation environment.
25th Jul 2020, 2:46 pm | #7 | |
25th Jul 2020, 4:45 pm | #8 |
15/16 was available on the Akai X-4 and X-5 and the Uher 4000 portables, to name but three.
25th Jul 2020, 4:59 pm | #9 | |
Re HiFi Show, yes I recall them , started 1960s or earlier? Unfortunately I was too far out of London and never made it to one TT |
25th Jul 2020, 5:58 pm | #10 |
The problem with pianos is that the string, having once been struck, vibrates at constant frequency, so any wobble is detected immediately. Conversely, wow correction software, such as Cedar Respeed, finds it easier to straighten pianos out than almost anything else.
25th Jul 2020, 6:19 pm | #11 |
27th Jul 2020, 11:50 am | #12 |
Revox supplied a special order low speed version of the A77 especially for logging in a radio studio. We still log in our studio, but this time it's at a low bit rate on a computer (running XP!) and a 320GB hard disc drive will easily hold six months of constant output.
27th Jul 2020, 12:37 pm | #13 |
Re #4, interesting observation on the 15/16 ips speed of standard VHS. Quite a few Christmas days ago, the BBC broadcast the complete reading of the first Harry Potter book by Stephen Fry, which I recorded on my then top of the range Panasonic S-VHS recorder, which had a seperate audio input with volume control and audio level meter, on the long play setting on a 5 hour tape.This would have given a linear speed of 15/32 ips. I normally only used the hi-fi stereo audio track for playback, but it did also record in linear mono. I still have the cassette but unfortunately the VCR is no longer working so I can't try out what 15/32 ips analogue audio sounds like.
27th Jul 2020, 2:35 pm | #14 |
I seem to remember seeing call logging equipment in comms rooms using VHS tape. Not my field, but I always took a superficial interest in all the other gear I came across. Racal possibly?
27th Jul 2020, 2:54 pm | #15 |
If they had started at 32 inches per second rather than 30 it would be much easier on the arithmetic.
27th Jul 2020, 3:00 pm | #16 |
I suspect logging audio only onto long play (LP) VHS was common. I have some such tapes from a radio station. All recorded in HiFi but the linear track is also there. At best the LP linear is good for 4 to 5 kHz. At LP speed the HiFi tracks can be unreliable. Sometimes a slight tweaking of the tape guide height helps with the switching noises and the machine and tape need to be in top condition.
27th Jul 2020, 3:51 pm | #17 |
Our open reel to reel machines were eventually replaced by a Racal Logging system. Rather than open reels, the Racal system used cassettes - about 25/50% bigger than a standard physical VHS cassette if I recall. Usefully the machine had 'end of cassette coming up' warnings that could be remoted to the operational control room which made life easier. (Station output on one track, transmission talkback plus TIM on the other).
27th Jul 2020, 4:10 pm | #18 | |
No idea where 77cm/s came from..... |
27th Jul 2020, 4:23 pm | #19 | |
27th Jul 2020, 5:52 pm | #20 | ||
