Old 2nd Aug 2020, 7:36 pm   #1
cathoderay57
Default Wanted 6EH5
Hello all, I'm repairing a Drake R-4B communications receiver for another Forum member. Checking the on-load voltages I'm getting a slowly rising dc voltage on grid 1 of the AF output valve 6EH5 as it warms up, rising to about +1.3v. I've disconnected the grid coupling cap but the voltage still rises so it ain't that. I've removed the valve and the grid voltage remains at zero therefore it cannot be a leaky valve holder. I've been unable to find a supplier of 6EH5 this side of the pond. A long shot, but I thought it would be worth putting out a request in case somebody has a decent one. Cheers, Jerry
cathoderay57 is offline
Old 2nd Aug 2020, 8:17 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Wanted 6EH5
Can you modify it to use something like an EL91? Even an EF91 is a possibility if you only need half a watt or so of output.
paulsherwin is offline
Old 2nd Aug 2020, 8:55 pm   #3
John_BS
I think 6CA5 might be equivalent? There' a guy in Spain selling a NIB on Ebay.
John_BS is offline
Old 2nd Aug 2020, 9:35 pm   #4
cathoderay57
Thanks for both suggestions. I'll hang on a bit in case anyone comes up with an exact replacement. The 6CA5 is pretty close, grid bias is easy to adjust if needed, other difference being 4.5k anode load impedance as opposed to 8k for the 6EH5 but unlikely to make much audible difference.
Old 2nd Aug 2020, 9:40 pm   #5
turretslug
Would it be permissible to re-wire the valve socket for something like a 6AQ5 that at least retains a US flavour (flavor?). Cathode resistor/grid bias would need changing to suit, but should provide adequate service in a comms receiver. The 6EH5 consumes nearly 8W heater power, which seems a lot for something in a B7g bottle!
turretslug is offline
Old 2nd Aug 2020, 10:09 pm   #6
cathoderay57
Probably a toss-up between EL90 (6AQ5), EL91 and EL95. All would be running at low anode and grid 2 potential (about 130v and 140v respectively) and so not producing their max output. All 3 would require a socket rewire which shouldn't be an issue. I've only got an EL95 so maybe I'll give that a go. I'm not even sure I should be worrying too much because the 6EH5 is only showing 5.1v on the cathode indicating a cathode current of 42.5mA, which is within the max spec for the valve. I'll run the set for a while and see if the current creeps up any further. Still interested in a 6EH5 if anyone has one. Cheers, Jerry
Old 2nd Aug 2020, 10:55 pm   #7
yesnaby
yesnaby's Avatar
https://www.ebay.de/itm/6EH5-TUBE-RC...QAAOSwT6pVqPB2
On eBay Germany, though valve is located in Spain!
The valve pins don't look too good though ....
yesnaby is offline
Old 3rd Aug 2020, 10:38 am   #8
cathoderay57
The owner preferred to keep the receiver original, so I've bought the spare identified in Post #7 - thanks for the tip, Yesnaby. Mods please close. Cheers, Jerry
