Old 19th Oct 2010, 4:33 pm   #101
ekcopyephilips
ekcopyephilips's Avatar
Default Re: Obsolete fluorescent light fittings
HHmmm OT i know but wasnt Newmarket transistors a subsidury of Pye ?
ekcopyephilips is offline
Old 19th Oct 2010, 11:45 pm   #102
Herald1360
Herald1360's Avatar
I don't know, someone will, though. Presumably at least based in the same town.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 20th Oct 2010, 12:20 pm   #103
Brian R Pateman
Brian R Pateman's Avatar
Yes, Newmarket was Pye's semiconductor offshoot.
Brian
Brian R Pateman is offline
Old 21st Oct 2010, 3:03 pm   #104
And the first hit on Google... http://www.wylie.org.uk/technology/s.../Newmarket.htm
Old 26th Oct 2010, 7:17 pm   #105
Tractorfan
Tractorfan's Avatar
When we bought our house here there were some ancient Philips 2ft 20watt fluorescent fittings in the attic so I took them down and put them on a shelf in the cellar. I've just realised that they've got dual voltage chokes. Now I know that France used to have 11Ovolts mains in some areas years ago, but I've never seen a 110/220volt choke before. Has anyone else? They've got three leads so I assume they're just centre tapped.
Cheers de Pete
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..."
Tractorfan is offline
Old 27th Oct 2010, 3:00 pm   #106
G0PKH - Pete
G0PKH - Pete's Avatar
I actually tried to buy an old tube the other day for my 1951 jukebox, it was 33" 25w and t12 in size, best I could get was a t8 which is too thin
I bought two from here the other day, for my Rockola 474 Machine which is nearing electrical completion.
http://www.jukeboxparts.co.uk/index....&productId=323
Hope this helps
Pete
G0PKH - Pete is offline
Old 27th Oct 2010, 10:49 pm   #107
twocvbloke
I remember going to a local electronics place in Burnleh wanting to buy a T8 UV Blacklight tube, and when I asked what they had in T8 sizes, the fella gave me a blank stare, and I spent about 15 minutes trying to explain to him the three main sizes, T5 (skinny things), T8, and T12 (old-style fat tubes), I even pointed at the T8's behind the counter, but he still didn't believe me, so I asked if he could get a selection of sizes, and he did, then he noticed printed on the UV tube I bought "T8 18W UVBL", so even the experts can't always get things right...
As for fittings, well, I have no idea of it's age (probably from the 90's), but I have one out in the workshop that was salvaged from the Colne leisure centre when they were replacing their old splashproof lights with something more modern. When I got it, it still had tubes (T8s) and starters and worked, but the tubes were beyond past it, they were very dim, and very slow starters, but replacing the tubes with brand new ones, and it's great, the diffuser's a bit yellowed though, but that creates a more comfortable light for people used to old incandescents, personally I like running it without the diffuser, but then the diffuser ends up getting in the way, so I end up putting it back on...
twocvbloke is offline
Old 28th Oct 2010, 10:04 am   #108
Courtney Louise
Courtney Louise's Avatar
Thanks Pete. Another problem I have had is getting 110V Choke and starter to fire through a step down TX.
Andi
33, 45, 78, around and around they go...
Courtney Louise is offline
Old 28th Oct 2010, 6:54 pm   #109
matthewhouse
matthewhouse's Avatar
Was it a real 110V choke, or one designed for series 240V use?
matthewhouse is offline
Old 29th Oct 2010, 2:05 pm   #110
Tractorfan
Tractorfan's Avatar
I've sometimes wondered about fluorescents designed for 110volts such as those in the USA etc. Would the longer tubes be more reluctant to strike, or is the gear designed differently (greater inductance perhaps)? I've never tried my dual voltage ones on 110volts.
Cheers de Pete
Old 29th Oct 2010, 2:38 pm   #111
Lucien Nunes
Presumably vintage french 110V chokes would be electrically different to ordinary US ones as they would be for 50Hz rather than 60. I have had issues with 60Hz fluorescents in this country. One 110/60 jukebox that the new owner proudly set up working on a step-down with a sleeved player motor shaft (to get the speed right) lasted about a week before the motor burnt out. I rewound it for him and a week later one of the florry chokes burnt out. We put in 240/50 chokes and a frequency changer for the motor.
I like to collect equipment rated for non-standard voltages such as were in use before the war. E.g. a 105V motor, 205V kWh meter, 210V vacuum, 460V heater etc. But as yet I have never come across a fluorescent fitting designed for anything outside 220-250V. Presumably few were made as they were only just getting into mass production by the time most supplies were standardised. Has anybody seen, say, 200V control gear for a standard tube?
Lucien
Lucien Nunes is offline
Old 29th Oct 2010, 6:10 pm   #112
matthewhouse
110V wound ballasts have an extra winding built in to step up the voltage, ive never seen flo ballasts with voltage taps (just metal halide and sodium ballasts).
Old 1st Nov 2010, 11:01 pm   #113
Hunts smoothing bomb
Hunts smoothing bomb's Avatar
Did you change the starter?
BG make one called an FS2, this starter is designed for 110v with a single tube or 230v with two tubes in series on one ballast.
Lee
Hunts smoothing bomb is offline
Old 4th Nov 2010, 5:19 pm   #114
jay_oldstuff
jay_oldstuff's Avatar
There seems to be a lot of very knowledgeable people posting in this thread so hope they can help with a quick question. can florescent tubes fail in storage? about seven years ago i was working at a school replacing all the old florescent fittings with new, i saved a number of good 8' and 5' tubes together with a number of 8' and 5' fittings two of the 8's I fitted in my garage and have worked fine still on the original tubes the other 8' fittings and all the 5' fittings i gave away over the years but kept a small number of the 5' tubes as they are the same as used in our kitchen.
a couple of days ago one of the kitchen tubes failed so i got one of my salvages spares out, it would not strike the filament lit and it attempted to strike but just wouldn't go i checked the tube against the old and it's 80w like the original. now i tested all these tubes before putting them away but thought must of missed one and it's a duffer however i have tried all five salvaged tubes and non will strike, i even tried the tube out of the other kitchen light in this fitting and it struck first time, but non of the salvaged tubes would strike in that fitting or the 5' fitting in the cellar.
anyone else heard of this?
Jay
The light at the end of the tunnel is probably the headlight of an oncoming train
jay_oldstuff is offline
Old 4th Nov 2010, 8:49 pm   #115
hamid_1
Jay, this may explain why your fluorescent tubes have become difficult to start. They are usually coated with a silicone coating which helps them to start. If the tube is damp or dirty, this can affect starting. Sometimes, switching on and running your finger along the tube from one end to the other while it's flickering will help it to start.
hamid_1 is offline
Old 4th Nov 2010, 10:28 pm   #116
Tractorfan
Tractorfan's Avatar
So, you could try polishing the tubes with silicon furniture polish and/or wrapping a few turns of fusewire from cap to cap and see what happens. I know that sometimes they can be sds to strike when they're cold.
Cheers, Pete
Old 4th Nov 2010, 11:08 pm   #117
jay_oldstuff
I'll give that a try before they go in the bin.
as it happens the fitting in the cellar is a double unit so i pinched one of it's tubes for the kitchen.
Jay
Old 7th Nov 2010, 12:20 pm   #118
geoff999
I have a couple of Phillips SL18s in the upstairs bathroom - marked "Made in Poland".
Quite happy with my milk bottles!
Geoff
geoff999 is offline
Old 7th Nov 2010, 9:09 pm   #119
Tractorfan
Tractorfan's Avatar
When they finally pack up you can use the glass bowl for all sorts of things. Whisky glass, flower pot, jam jar, the list could go on .
Cheers Pete
Old 8th Nov 2010, 12:06 am   #120
Jason Pero
-bayonet linear fluorescent tubes, how one fit into the sockets even those bayonet is meant to be inserted and turned to lock?
-Bad/corroded/dirty bi-pin sockets even the fluorescent tubes do light up normal shorten life-time severely from 1-2 years down matter of months and splutter out? Reason thing is our TV shop suffers from these even they got new ballasts and tubes for energy saving. They recycled the old fixtures with those grubby sockets instead of replacing them entirely. Which I frown.
Cheers, Wizard
Jason Pero is offline
