Old 27th Feb 2019, 6:07 pm   #1
McMurdo
McMurdo's Avatar
Default High Vceo audio transistors
I'm trying to fix an audio amp which uses MJL4302/4281 pairs. Vceo is 350V and the amp requires 'selected' 410V transistors. The OEM no longer supplies them. AN Other has fitted stock transistors and they failed.
Just wondering about the possible solutions?
Kevin
McMurdo is offline
Old 27th Feb 2019, 6:08 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: High Vceo audio transistors
Sounds like a pretty silly design to me.
paulsherwin is online now
Old 27th Feb 2019, 6:13 pm   #3
I'm with Paul here, maybe buy a dozen and test? Or reduce the HT voltage and use standard ones. Are there any other 450V types out there?
Old 27th Feb 2019, 6:18 pm   #4
McMurdo
McMurdo's Avatar
It does sound a strange design but there you go. I can't just see anything easily available, which is maybe why the OEM used selected ones, it happens sometimes in audio amps. How do I diy-select for high-Vceo ?
I don't think reducing the voltage is easy as it's 240 in, transformer-rectifier-capacitor supply out.
The amp is a 'transformerless' 100V line amp, driving the 100V line directly.
Kevin
McMurdo is offline
Old 27th Feb 2019, 7:30 pm   #5
Al (astral highway)
Al (astral highway)'s Avatar
What about horizontal output transistors like 2SD1555? Burly and within spec by some margin ...
Al
Old 27th Feb 2019, 7:52 pm   #6
ionburn
ionburn's Avatar
I have used some 700V ones in the past (PHE13009), but they are principly designed for switching. I successfully used them in high voltage capacitance multipliers, but their gain is very low. Nowadays with more use of FETs I suspect choice maybe limted.
ionburn is offline
Old 27th Feb 2019, 8:21 pm   #7
G6Tanuki
G6Tanuki's Avatar
Motorola made some: in the past I've used the likes of the MJE340 in a classic 'single-ended' Class-A output-stage with a couple of hundred volts of HT.
There were similar single-ended class-A outputs used in a number of 1970s TVs, clearly designed around the "what can we cheaply fit in place of the beam-tetrode?" make-this-TV-transistorised-at-lowest-possible-cost basis.
G6Tanuki is offline
Old 27th Feb 2019, 9:09 pm   #8
sortedradio
sortedradio's Avatar
Hi Kevin,
Cloud Electronics CXV425 amplifier uses MJL4302/4281 transistors selected for high voltage.
I bought some from the in October last year, they come as part of a repair kit for the amp.
Martin
BVWS member
GQRP Club
sortedradio is offline
Old 27th Feb 2019, 9:29 pm   #9
MotorBikeLes
Grundig used the MJE340 in the sound output of the 1970 model 717, they are rated at 300v. I used to replace with BD410, my book givs 500v for those, so worth a try.
I probably still have some if you are stuck.
Les.
Last edited by MotorBikeLes; 27th Feb 2019 at 9:30 pm. Reason: Punctuation and sp.
MotorBikeLes is offline
Old 27th Feb 2019, 9:43 pm   #10
Red to black
Red to black's Avatar
The two numbers given by the OP are a complementary pair, ie. both NPN and PNP types.
The MJL4281 being NPN and MJL4302 being its PNP counterpart.
Edit: see here:
https://www.onsemi.com/pub/Collateral/MJL4281A-D.PDF
He also needs specially selected 410V Vceo types or a suitable substitute for another complementary pair.
Post#8 by Sortedradio might help.
Red to black is offline
Old 27th Feb 2019, 11:24 pm   #11
Herald1360
Herald1360's Avatar
https://electronics.stackexchange.co...-series/285259
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 28th Feb 2019, 12:56 am   #12
McMurdo
McMurdo's Avatar
Hi Kevin,
This is the amp. Cloud no longer supply them.
Kevin
McMurdo is offline
Old 28th Feb 2019, 2:42 am   #13
Boater Sam
Not very helpful but should it not be using valves with this HT?
Boater Sam is offline
Old 28th Feb 2019, 3:53 am   #14
Refugee
Refugee's Avatar
There is a compliment for IRF840 and many others.
They go up to 800V.
It would require some modification but would cut the cost of repairs.
Refugee is offline
Old 28th Feb 2019, 8:00 am   #15
Diabolical Artificer
Diabolical Artificer's Avatar
Digikey show over 5 pages of BJT's with a collector/emitter breakdown of 450v, several similar parts to the MJL4302, like the MJE18004, with a ceo of 450v - https://www.onsemi.com/pub/Collateral/MJE18004-D.PDF, surely you'll be able to find a replacement or am I missing something?
Andy.
Old 28th Feb 2019, 9:58 am   #16
sortedradio
Originally Posted by McMurdo View Post
Hi Kevin,
You could try Full-Volume in Sheffield (0114 244 8891) who distribute Cloud kit. They have been helpful in the past.
Martin
BVWS member
GQRP Club
Old 28th Feb 2019, 10:29 am   #17
Radio Wrangler
Radio Wrangler's Avatar
Ah, it's a high power 100v line driver.... presumably using high voltage transistors to dodge the use of a transformer on the output.
Understandable, I suppose, but as the speakers are going to be connected using transformers, maybe one at the drive end isn't quite so devastating. At least there's a reason for those high voltage transistors, though no real excuse for using specially selected ones.
Radio Wrangler is offline
Old 28th Feb 2019, 10:44 am   #18
McMurdo
McMurdo's Avatar
Here's the beastie, each amplifier has 4 channels, 2 in each 'heatsink tunnel', the right hand module has been removed. Everything's a bit tight.
I'm not confident fitting non-audio specific transistor equivalents, given its history, and I'm supposed to be the one to effect a permanent 'fix'.! Most high voltage, high current transistors in this range seem to be designed for switching use, and dont easily track/load share in the linear mode. Sometimes these things like to oscillate as well.
Kevin
McMurdo is offline
Old 28th Feb 2019, 10:58 am   #19
sortedradio
"at extended mains voltages (eg. 260v) those transistors can be swinging just shy of 400v. We test each transistor, and only use those which are capable of at least 405v." - Cloud Electronics
Martin
BVWS member
GQRP Club
Old 28th Feb 2019, 11:01 am   #20
lesmw0sec
It is not always realised that the breakdown voltage can be measured (non-destructively) by using a variable power supply feeding the C/E via a high value resistor to limit the current. As the voltage increases, a meter across the device will show the voltage level off at the breakdown voltage (a bit like a zener diode).
lesmw0sec is offline
