8th May 2018, 12:24 pm | #1 |
Unmarked transistor identification.
I have a metal cased npn transistor that has no marking on it, how can I tell if its ge or silicon?
regards poppydog |
8th May 2018, 12:55 pm | #2 |
No Longer a Member
Re: transistor identification
Typical digital meter with a diode/beep setting will give about 0.35V on the base emitter connection for germanium and about 0.65v for silicon
Or, if you just have a volt meter, set up a battery, say 9V with a series resistor say 10k to forward bias the base-emitter junction and measure its voltage drop, will be around 0.3v for germanium and 0.65v for silicon. Probability dictates its a silicon, as NPN germaniums are not wonderfully common, but it still could be one. |
8th May 2018, 1:02 pm | #3 |
Thanks for that Argus25
regards poppydog |
9th May 2018, 9:37 am | #4 |
Re: Unmarked transistor identification.
What happens if the transistor is knackered, how do you identify it then?
regards poppydog |
9th May 2018, 9:44 am | #5 |
You can only do basic tests such as for leakage, forward gain and so on.
Without knowing what it is, its impossible to go further. For example some small signal RF types have very limited voltage and current ratings, perhaps as low as 12 volt and 50ma. As its unmarked, how did you determine it to be NPN ? (just curious ) |
9th May 2018, 10:09 am | #6 |
I asked what would happen out of curiosity, the transistor in question was very low gain as indicated on a transistor tester
regards poppydog |
9th May 2018, 10:40 am | #7 |
The cheap multi-device testers from your 'local' Chinese supplier will give you all the basic parameters of such devices. Pinout, polarity, gain, Vbe etc.
They are, imho, the most useful pieces of test equipment anyone can have these days - they come into their own (for my purposes) when trying to identify the pinout of the TO92 devices which are often confusing despite datasheet information! For around a tenner you can't go wrong. |
9th May 2018, 12:51 pm | #8 | |
Using a DVM (or analogue meter... an AVO8 is great for general transistor checking) takes only a few seconds to identify NPN or PNP, and the analogue meter on a high ohms range can be a good guide for testing for leakage. True low gain (with no other problems such as being leaky) is not all that common a failure mode in my experience. |
