30th Apr 2018, 8:25 am | #1 |
Parts donor - receiver?
I want to experiment with some simple radio reception circuits (superhet) using discrete components and 'proper' tuned circuits. I'm referring to the miniature IFTs with the red/white/yellow tuned cores.
Since IFT's aren't that easy to come by I was hoping to use an old transistor radio as a 'parter' - there have to be dozens that could fit the bill and not grate on ones conscience for dismantling in such a way. Can anyone recommend a make/model of set that would provide me with such parts and that wouldn't cause cardiac arrest in the community for the horror I'm about to comit Ideally the make/model would be common such that if I wanted to duplicate any construction then I'd be able to (re)access additional parts in the same way. |
30th Apr 2018, 9:03 am | #2 |
Re: Parts donor - receiver?
You could also get IFTs from the radio section of a dumped music centre or radiogram, which widens your range of availability.
If you go for a Japanese built set rather than a Hong Kong or Chinese one, you may be able to find data on the IFTs in an archived Toko catalogue. If you fancy being really experimental, you could look for a 12kHz wide crystal filter on 1.4MHz and build an up-converter. Long and medium waves in one band with no gap. I've found these filters on amateur radio rally stalls in the past. David
30th Apr 2018, 9:17 am | #3 |
The common and cheap Chinese radio kits (HX108, S66E etc.) contain those IFTs and would save the trouble of de-soldering. (IFTs are not the easiest things to remove.)
Last edited by G8UWM-MildMartin; 30th Apr 2018 at 9:19 am. Reason: remove confusion |
30th Apr 2018, 9:38 am | #4 |
Hold can, pull gently, play small blowtorch on reverse side of PCB.
It all depends on what you want to keep. david
30th Apr 2018, 10:04 am | #5 |
I'd recommend looking out for an old/rough-looking Fidelity set from the late 60's/early 70's. These contain Toko 10mm IFT's and that's where I got some to use in my Theremin...
Some of the Chinese radio kits use 7mm types if that is important to you. Andy |
30th Apr 2018, 2:13 pm | #6 |
You're welcome to this "chassis" for the cost of the postage, approximately £3. It's about 15" long.
Sorry about the poor pictures, but it's to wet to photograph it outside today. PM me if interested.
30th Apr 2018, 6:54 pm | #7 |
Access to 'dumped' equipment isn't a real possibility for me given my remote location so any parts I try for will inevitably be from an auction site or snapped up if offered via the forum (thanks Graham).
Fidelity? Not a name I've come across but one I'll be searching for, thanks for the tip. |
