11th Oct 2004, 9:55 am | #1 |
Valve functional equivalents
Valve equivalent lists nomally list valves that are pin and functionally compatible. But I recently heard that some modern valves may actually be more or less the same as older versions.
Does anyone know of any lists of equivalents that are NOT pin compatible but are compatible at the characteristic level. Or perhps of near equivalents, e.g. where the heater is different (of course you can often guess these - but it seems not always correctly). |
11th Oct 2004, 11:29 am | #2 |
Re: Valve functional equivalents
Go to http://hereford.ampr.org/cgi-bin/tube
Look up a valve and then scroll to the bottom of the page and click on the " Same Chars " box. A whole load of electrically equivalent valves will be listed. I have never tried this in anger, so I don't know how good it is. Graham
11th Oct 2004, 11:58 am | #3 | |
11th Oct 2004, 12:28 pm | #4 |
Hi Gents the 50's and 60's Wireless World valve data book does this for you very well as the details are listed in tabular form by heater volts and is easy to scan. There must be many copys of this A4 size booklet about unless someone has scanned it to CD.
Ed |
11th Oct 2004, 6:33 pm | #5 |
Hi
Here is something that just came up on another forum which might be useful. http://antiqueradios.com/forums/Foru...ML/003921.html Norm |
11th Oct 2004, 7:29 pm | #6 |
The Mullard maintainance manual gives lots of alternatives with base / component changes, though you have to work backwards to get it!
Jim. |
6th Mar 2005, 11:39 am | #7 | |
Administrator
