Old 3rd Mar 2021, 11:25 pm   #1
Bufo Bill
Bufo Bill's Avatar
Default Garrard sprucing up!
Planning on a spruce up of the Garrard 401 I bought locally a couple of winters back. Main thing I am planning is mucking out the spindle bearing.
My question to you all is as follows:-
What is the best cleaning agent for 50 years of grease Clag?
Will be looking for a service manual shortly, but I would also like to hear what oil is best to replace in the clean bearing if you have any ideas about that.
Cheers from Bill.
Bufo Bill is offline
Old 4th Mar 2021, 9:53 am   #2
Electronpusher0
Default Re: Garrard sprucing up!
According to the forum on Vinylengine light machine oil, sewing machine oil is fine.
https://www.vinylengine.com/turntabl...ic.php?t=89900
Peter
Electronpusher0 is offline
Old 4th Mar 2021, 2:34 pm   #3
Bufo Bill
Bufo Bill's Avatar
Cheers Peter.
Thanks from Bill.
Old 4th Mar 2021, 2:55 pm   #4
Beobloke
For cleaning out the old goop, you can’t beat IPA (no, not the beer...).
Replacement oil-wise, you can’t go far wrong with 3-in-1.
Beobloke is offline
Old 4th Mar 2021, 4:04 pm   #5
Bufo Bill
Bufo Bill's Avatar
Ah, that's great, already have both of those, thanks Beobloke!
Bill.
Old 4th Mar 2021, 9:54 pm   #6
wd40addict
wd40addict's Avatar
At the expense of sounding like a Hi-Fi reviewer, I tried sewing machine oil in my 301 once and it didn't sound as good as something a little thicker. At least on my example if the oil is too thin the bearing can rock slightly side to side.
wd40addict is offline
Old 5th Mar 2021, 1:32 pm   #7
Bufo Bill
Bufo Bill's Avatar
Cheers wd40addict!
Old 5th Mar 2021, 11:06 pm   #8
Electronpusher0
The early 301s used grease, the later ones used tighter tolerance bearings and moved to oil. This was carried over to the 401.
Peter
Old 5th Mar 2021, 11:52 pm   #9
wd40addict
wd40addict's Avatar
Mine is an oil bearing unit and I would still say sewing machine oil is too thin.
