Old 2nd Dec 2020, 8:39 pm   #1
murphyv310
murphyv310's Avatar
Default System A Ch1 modulator using MC1374.
Hi.
I have four MC1374 IC's that were used in a Channel 1 405 line modulator some years ago.
I need to build one up but have no info at all on it.
Does anyone remember these and if perhaps a PCB was or is available with a circuit.
Mods I'm not sure if this should be posted here or in the info wanted section, please move if necessary, thanks.
Trevor.
2M0GZQ BVWS, GQRP KLARC. Member
murphyv310 is offline   Reply With Quote
Old 2nd Dec 2020, 8:52 pm   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: System A Ch1 modulator using MC1374.
One that I built a long time ago was in 405 Alive
Perhaps it was that one?
Now Here
https://www.bvws.org.uk/405alive/tech/modulator.html
Mike T
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline   Reply With Quote
Old 2nd Dec 2020, 10:21 pm   #3
Restoration73
Restoration73's Avatar
pages 59-61
https://worldradiohistory.com/Archiv...cs-1982-02.pdf
Restoration73 is offline   Reply With Quote
Old 2nd Dec 2020, 10:41 pm   #4
FRANK.C
FRANK.C's Avatar
Hi Trevor
Circuit and PCB + some other parts are available here from ETF
Frank
FRANK.C is offline   Reply With Quote
Old 2nd Dec 2020, 11:56 pm   #5
murphyv310
murphyv310's Avatar
Thanks chaps.
The ETF one is it.
I made a couple many years ago, someone here gave me a couple of boards, both went to other collectors. I've one to make up and try at a lower frequency for a project.
All will be revealed in due course.
I've all the bits but no board unfortunately.
Trevor.
Old 3rd Dec 2020, 8:20 pm   #6
Ed_Dinning
Hi Trevor, was this one used in the David Loser cct in Television?
Ed
Old 4th Dec 2020, 12:34 pm   #7
FERNSEH
FERNSEH's Avatar
The attachments show an early ETF modulator. The example I have here required considerable modification before it would work.
The MC1374 was designed for negative modulation systems, that being the case a separate sync tip clamp is used to so that the sync tips can reference to zero modulation. An emitter follower is introduced between the input amplifier and the input pin of the MC1374. Seems that the IC demands a low impedance drive.
The carrier oscillators can be modified to crystal resonators.
Modulator will work on channel B4 frequencies.
Information about the MC1374.
https://www.circuitspecialists.com/c...27/mc1374p.pdf
DFWB
ID:	221836   Click image for larger version
FERNSEH is offline   Reply With Quote
Old 8th Dec 2020, 11:59 pm   #8
rambo1152
rambo1152's Avatar
I built the ETF modulator on a breadboard three years ago to use with a PC graphics card project. It works so well it's still in the state you see it here.
ID:	222147 Click image for larger version
I have started to build a slightly more presentable one on perforated project board, I must get round to finishing it.
Anyway, my point is the absence of a custom PCB shouldn't put anyone off.
Mine is tuned to B2, the free-running oscillators are no problem, set and forget. I didn't bother with the output filter, I don't think David did either.
Graham.
G3ZVT
