12th Sep 2013, 5:09 pm | #1 |
Eagle K-140 Multimeter
Hi
Bought this at local car boot for a quid . The seller had no idea of its history . Has anyone any experience with one of these meters ? I'd say early / mid 70's . Reminds me of those 70's Japanese hifi seperates ' built like battleships ' I think the phrase went . Excellently large scale , nice leather carrying strap and presumably it originally had a leather case with a space for carrying the test leads . Unfortunately its reading slighly low on all scales , a consistant error although theres no 'sticky ' spots which indicates a duff meter mechanism . The needle swings smoothly across whole scale . Maybe a bit of friction in meter due to years of being unused . Anyhows , I think it's a keeper if only for the sheer size of the beast Cheers . . |
12th Sep 2013, 5:35 pm | #2 |
Re: Eagle K-140 Multimeter
Eagle made quite a lot of hobbyist test gear at that time. It's all quite well built though a bit crude. I have the TT145 transistor tester, which is actually still usable, though the hfe reading is pretty inaccurate once it gets over 200.
12th Sep 2013, 8:06 pm | #3 |
Those were quite decent meters. If all ranges have shifted the same amount, it might be loss of magnetisation in the meter. If there isn't a single shunt resistor to take care of this, then you face changing every resistor in the beastie :-(
12th Sep 2013, 9:25 pm | #4 |
Paul, just to clarify, Eagle made very little - if any - themselves. They badge engineered most of it. The meter in question is a Kyoritsu K-140. They did not even change the model number.
I have an Eagle K-142 that looks almost identical to the K-140. You can find pictures of the K-142 as a Kyoritsu on the Radiomuseum site. enquirium, you may be lucky. I had to replace a few resistors on my meter to get the accuracy back. Hopefully it is just a resistor that needs changing. I have just had a look at the last picture. The three pots on the board in the middle are almost certainly calibration pots. If you succeed in getting it to full spec I have, somewhere, a bag of spare rubber feet and the US thread screws that you can have a couple from. Al
I won't tell you how I discovered that. Last edited by Alistair D; 12th Sep 2013 at 9:36 pm. Reason: Added paras |
13th Sep 2013, 4:29 pm | #5 |
Many thanks folks .
They are indeed calibration pots Alistair D . As you can see below. I'll have a twiddle and see if I can compensate for the error . Cheers. |
13th Sep 2013, 5:09 pm | #6 | |
They chose their suppliers well, mostly from Japan, and had a reputation for good quality at an affordable price. I have one of their table radios in the loft somewhere, very similar to products from Roberts and Grundig of the same era. |
13th Sep 2013, 6:09 pm | #7 |
Taylor's (available) Ltd.... a component shop in Huddersfield stocked a lot of their stuff especially multimeters and components.
I came across their range of little audio mixers and PA amplifiers which were cheap, effective and very good value. I had some of their cheap microphones and a pair of stereo headphones. I agree with Paul that Eagle stuff was very good value, and it's interesting to hear a bit about who they were. David
13th Sep 2013, 6:20 pm | #8 |
Their catalogue was a source of great interest to me during my formative electrickery years! More than one home build speaker system issued from my adolescent bedroom workshop using drive units and crossovers from Eagle!
BVWS member |
13th Sep 2013, 8:10 pm | #9 |
Here's a one I was given a few years ago. The pointer is very sensitive to static when running a finger over the meter!
It's a 'KEW-33' but is badged up as 'Eagle'. It still has the price on the box: £8 - 12 - 0.
Regds, Russell W. B. G4YLI. |
13th Sep 2013, 9:31 pm | #10 |
That was the first meter I ever owned. Bought it new around 1968. Eventually the case ended glued together from having been dropped a few times. It still worked when I gave it away years later.
Al
I won't tell you how I discovered that. |
