Old 20th Jan 2013, 7:48 pm   #1
3nf
3nf's Avatar
Default Tin whisker growth on potentiometer
This Cossor 1052 oscillograph had various faults; no Y shift, focus and brightness problems. This was found to be due to a short circuited Y shift pot. On removing it, it was still shorted, so I removed the back cover. The fault then went away. There are tin whiskers inside the cover which were shorting both the ends of the pot together, but not the wiper.
Anyone had this fault?
Name:	Tin whiskers.jpg
ID:	75224   Click image for larger version
Name:	Cossor 1052 oscillograph.jpg
He's gone to make his meter.
3nf is offline
Old 21st Jan 2013, 7:15 am   #2
Refugee
Refugee's Avatar
Default Re: Tin whisker growth on potentiometer
There have been many posts about fly by wire car accelerator pedal tin whiskers including lawsuits about cars going full throttle due to the same problem.
Take a web search and have a read.
The pot on the pedal has the same problem.
Refugee is offline
Old 21st Jan 2013, 9:46 am   #3
Radio Wrangler
Radio Wrangler's Avatar
It's a very well known problem and has got a lot worse since the switch-over to unleaded solder. Though the Cossor scope far pre-dates that.
Some applications (aeroplanes but not cars) are still allowed to use lead in their solder.
Tin dendrites will grow along surfaces quite easily, and even upward across fresh air. All they need it the presence of tin and a bit of electric field to impel them.
Last edited by Radio Wrangler; 21st Jan 2013 at 9:47 am. Reason: forgot one sentence!
Radio Wrangler is online now
Old 21st Jan 2013, 12:22 pm   #4
Nickthedentist
Nickthedentist's Avatar
No, I've never had it on a pot. Rather scary about car accelerators, as I think the vast majority if not all are "fly by wire" nowadays.
Nickthedentist is offline
Old 21st Jan 2013, 1:01 pm   #5
M0FYA Andy
I spent my career as a systems engineer working on military aircraft fly-by-wire flight control systems. I remember a visit back in the mid-80's by a couple of engineers from one of the motor-car manufacturers, I think it was Jaguar, looking for any advice we could give on using similar technology for steering and braking sytems on their products.
They were quite taken aback when it was pointed out that a military aircraft flight control system typically uses four lanes of sensing and computing, with cross-monitoring between lanes to identify and isolate failures. They didn't see how a system in a motor car could ever be more than simplex, on cost grounds.
The thought frightened me then, and it still does!
Andy
M0FYA Andy is offline
Old 11th Feb 2013, 10:08 pm   #6
ScottBouch
ScottBouch's Avatar
Originally Posted by M0FYA Andy View Post
military aircraft flight control system typically uses four lanes of sensing and computing, with cross-monitoring between lanes to identify and isolate failures.Andy
One reason why our Lightning would never be allowed to fly in the UK... Lack of redundancy in the control systems. 15 tonnes of Mach 2 in private hands is another reason!
I'd not come across this property of tin before, it's fascinating! What age do you estimate your pot to be? -ie what growth rate do these whiskers have?
Cheers, Scott
www.scottbouch.com
ScottBouch is online now
Old 12th Feb 2013, 6:12 pm   #7
jhalphen
Hello to All, 3NF,
Read the full story on tin whiskers and by none less than NASA itself!
http://nepp.nasa.gov/WHISKER/background/index.htm
http://nepp.nasa.gov/whisker/photos/index.html#semi
Makes you shudder...
Best Regards
jhalphen
Paris/France
jhalphen is offline
Old 12th Feb 2013, 6:24 pm   #8
kalee20
Originally Posted by jhalphen View Post
... by none less than NASA itself!
... with input from Paul Stenning!
kalee20 is online now
Old 12th Feb 2013, 8:27 pm   #9
3nf
3nf's Avatar
Hi Scott
The tin whiskers on the Cossor 'scope had 50 odd years to grow. The set has only been running for a couple of hours in the last 5 years, so can't be attributed to an electric field.
The first time I heard of this was when bronze anodes on 100KV electron beam microlithography machines grew whiskers and shorted out the EHT. These bronze anodes were quickly replaced with stainless steel. End of problem.
chris
3nf is offline
Old 14th Feb 2013, 12:36 am   #10
McMurdo
McMurdo's Avatar
Most car accelerators have 2 pot tracks that have to track each other at all times. If the signals disagree then on goes the engine light and limp mode soon after!
I think military and medical devices must change to ROHS ?
Kevin
McMurdo is offline
Old 14th Feb 2013, 10:02 pm   #11
60 oldjohn
Just seen an interesting article on the Net, Please Google, 125mph nightmare.
John.
60 oldjohn is online now
Old 21st Feb 2013, 2:58 pm   #12
G8HQP Dave
I don't know if this NPL webinar is of interest to anyone. You need to book, but it is free.
G8HQP Dave is offline
