25th Nov 2019, 2:42 pm | #1 |
Grundig TK20 reel to reel tape recorder
I have a Grundig TK20 tape recorder which I have had since the very early 60’s. This works perfectly although the volume control needs to be at maximum to hear the recordings. Does it need a new amplifying valve and if so is it difficult to replace?
27th Nov 2019, 1:32 pm | #2 |
Re: Grundig TK20 reel to reel tape recorder
It is highly unlikely to be a valve replacement issue - if only it were that easy!
I suggest the playback head is dirty/worn - and/or there is a low HT supply. What is your level of experience is servicing or fault finding on these vintage R2R machines?
Edward. |
30th Nov 2019, 4:31 am | #3 |
I would connect a PC output put to the input and test the volume. If using another input source the audio is loud, then the problem will most likely be a worn or corroded head.
If the volume is low with the PC input source, then i would check the voltage after the main filter caps, if low, most likely the old rectifiers will need to be replaced, as they can drop the output voltage over time. If it has not worked for a while, the original motor run capacitors will surely fail.. just a question of when. |
1st Dec 2019, 7:53 am | #4 |
Is it possible that the tape on the spool has been wound
or creased so the shiny side faces the head ?
Steve Dow VE7ASO |
1st Dec 2019, 12:42 pm | #5 |
Another check along those lines is the felt pressure pad on the head (if it has one. I think some Grundigs used a taught band instead) It may have fallen off due to old adhesive or needs replacement anyway.
2nd Dec 2019, 11:38 am | #6 |
I've worked on the TK20 as it was a model common in the 1960s.
I distinctly remember the condenser mike. If the music and words on the tape can be heard distinctly under a hum and hiss, the head is OK, and a contact or dirty valve pin might be suspect. With a blank take, a recording might be tries, to see if speaking into the microphone causes the EM 84 to deflect. Below is a peek at the description in Hickman, 3rd ed., Magnetic Recording Handbook.
Steve Dow VE7ASO |
2nd Dec 2019, 1:50 pm | #7 |
One of the first things I'd check on a machine of this age would be the coupling capacitors. Grundig tended to use Wima in those days, which (among other manufacturers) are notorious for increased leakage with age, leading to incorrect valve biasing with consequent low volume, scratchy volume control, distortion, complete silence and output transformer overheating depending on how severe the problem is.
5th Dec 2019, 12:16 pm | #8 |
It's 12 days since the OP posted, but there's been Radio Silence since.
I hope we've not scared him off with all of these optional suggestions.....?!
Edward. |
5th Dec 2019, 1:28 pm | #9 |
The OP hasn't visited the forums since he posted. This is not uncommon I'm afraid.
There's no need to discuss this any further.
