24th Oct 2019, 2:18 pm | #1 |
Radiospares Tapped Choke
Can anyone suggest what would have been the intended application for a Radiospares Tapped Choke, 150mH at 0.9Amps, please?
When did Radiospares change their name to RS Components, that dates it to a degree? Many thanks, Andy |
24th Oct 2019, 2:32 pm | #2 |
Re: Radiospares Tapped Choke
24th Oct 2019, 3:41 pm | #3 |
Lawrence, thanks. Although I'm not really any wiser how it would be used, other than as a simple smoothing choke in a low-voltage high-current supply. Was there a Radiospares application note of any sort?
Andy |
24th Oct 2019, 3:57 pm | #4 | |
Lawrence. |
25th Oct 2019, 12:29 am | #5 | |
catalogue (83 pages of 9-1/4 x 6"). I don't think they produced datasheets in those days. Looks like it was tapped to allow matching to different impedance speakers in car radio applications etc. Here's a scan: Last edited by m0cemdave; 25th Oct 2019 at 12:53 am. |
25th Oct 2019, 2:52 am | #6 |
Given it provides a 1:1 winding with 15 ohm tap as CT, and it is nice audio quality, there may be a push-pull output stage arrangement with each end of the choke connected to PP cathodes, and the CT connected to ground or bias as a common-cathode point.
The only vintage scheme I can recall that is 'somewhat' related was the Parry Cathamplifier, but it used a transformer. https://dalmura.com.au/projects/Cathamplifier.html |
25th Oct 2019, 8:02 am | #7 |
25th Oct 2019, 8:15 am | #8 |
Many thanks for the replies. I bought one recently simply because it had me puzzled and I find vintage components fascinating!
In some ways it seems like a solution looking for a problem, but that's not how Radiospares worked, they supplied the parts which everybody wanted. So there must have been a good market at the time. Andy |
