Old 18th Jun 2019, 10:55 pm   #1
martin.m
martin.m's Avatar
Default Non broadcast uses for low frequencies
I have been looking at Ofcom's UK frequency table which lists the band between MW and LW (526.5 KHz to 283.5 KHz) and below LW (148.5 KHz right down to 8.3KHz) as being allocated to maritime mobile and aeronautical radionavigation use. Below 8.3KHz is not allocated. In this age of satellites, GPS etc are these low frequencies really any use for communication and navigation?
Regards
Martin
martin.m is offline
Old 18th Jun 2019, 11:18 pm   #2
Julesomega
Julesomega's Avatar
Default Re: Non broadcast uses for low frequencies
Below the LW Broadcast band, see VLF Stations List
Between LW and MW there are still a few NDBs left, but the move now is to DGPS, see The DGPS List
- Julian
It's good here
Julesomega is offline
Old 18th Jun 2019, 11:21 pm   #3
Paul JD
NDB's (non directional beacons) use the frequency range 190 kHz to 535 kHz and are still very much in use in aviation.
Paul JD is offline
Old 18th Jun 2019, 11:22 pm   #4
Julesomega
Julesomega's Avatar
See also the thread Ultra VLF signals?
- Julian
It's good here
Old 18th Jun 2019, 11:48 pm   #5
paulsherwin
paulsherwin's Avatar
I believe VLF is still used for military submarines:
https://en.wikipedia.org/wiki/Commun...ith_submarines
https://en.wikipedia.org/wiki/Anthorn_Radio_Station
paulsherwin is offline
Old 18th Jun 2019, 11:54 pm   #6
Paul JD
Originally Posted by Julesomega View Post
Between LW and MW there are still a few NDBs left[/URL]
Over 100 NDB's currently in use in the UK
http://www.infotechcomms.net/downloads/ndbs.pdf
Paul JD is offline
Old 19th Jun 2019, 12:19 am   #7
martin.m
martin.m's Avatar
Thank you for your replies, this is a fascinating subject. Do land based navigation systems have any advantage over satellite GPS? On a separate note, 135.7KHz to 137.8KHz is also allocated for amateur use with a maximum ERP of 1W. What would amateurs use this band for?
Regards
Martin
martin.m is offline
Old 19th Jun 2019, 7:35 am   #8
Stockden
There's information about the 136KHz band here.
Hugh
Stockden is offline
Old 19th Jun 2019, 8:52 am   #9
Paul JD
The Flight Management System on a typical airliner uses several sources of position information including ground based nav aids, an inertial reference system (gyros and accelerometers) and GPS. This provides redundancy and cross checking, using GPS alone would not be a viable option as it would not provide the necessary back-ups (in fact ground based nav aids are still very much considered the primary navigation source with GPS used for backup and cross checking). Also as the GPS system is owned and operated by the US government it could in theory be switched off or degraded at any time, although this is unlikely it does mean that it would be unsuitable as the primary navigation source for commercial aircraft.
Paul JD is offline
