1st May 2019, 8:48 pm | #41 | |
No Longer a Member
Re: So what's the deal with single ended hifi amps?
A transformer might cost initially more because of the much lower volume manufacturing than a valve, but mostly, they out last a vacuum tube. Also both the valve and the transformer core have non-linearities in their transfer functions, and there is no escaping that. |
1st May 2019, 9:12 pm | #42 |
Single-ended amps can sound great! I've got a stereo amp that uses a 6V6 for each channel and it sounds good to my non-golden ears.
One thing that puzzles me is why none of the hi-fi types have ever used the idea of 'sliding bias' to get the most out of their expensive valves. At low audio-level wind the -ve grid-bias up so the valve is passing just-enough current. Then when you want more loudness, reduce the grid-bias so the anode-current rises in order to deliver the greater output. [alternatively, if you're a heretic who is using tetrodes/pentodes, slide the screen-grid bias up and down to control anode current in the same way as 'series-gate' AM modulation worked in amateur transmitters] |
1st May 2019, 9:58 pm | #43 | |
I also have a stereo SE amp based on a pair of 6V6 in pentode, first stage is an ECC81 and its jolly pleasant too! It does get a bit flustered when the wick is turned up but in its defence i was driving 87dB sensitivity speakers and its really only good for about 1.5W before the distortion gets in the way. It's only running at about 240VHT though so we can forgive it! And the output transformers are at best a bit weedy I think so not surprising. But as a small domestic amp with a sensitivity of about half a volt its not half bad, with a very low component count. It's basically an adaptation of the Alex Kitic RH84 design which uses anode feedback and I am not using it with his ideas of zeners to supply the screen grid, nor CCS on the cathode as I reckoned they did nothing good for it apart from inducing instability. Hi Fi? Well no, unless you listen in a 8 x 6 foot cupboard, but at sensible late night levels its never less than nice. And surprisingly completely hum and hiss free which I put down to OCD heater wiring and earthing and a deliberately low sensitivity. I liked your ideas about the biasing, but for me if I felt I needed to do all that complication I'd just get a good solid state power amp. My feet are planted in both camps and if its good its good and I dont apply religion. Finally confession time, bless me father for I might sin...................... But I quite fancy building up an SE power amp using EL34 or KT88 types for a bit of usable power. Mainly because I am curious and the parts can be gleaned from here and there or even adapted from one of the dodgy Chinese kits but I'm dubious about their output transformers. Keeps me out of the pub I suppose.................... A. |
1st May 2019, 10:21 pm | #44 | |
No Longer a Member
(ps my own stereo amplifier is push pull ultralinear 6L6's) |
1st May 2019, 11:06 pm | #45 | ||
1st May 2019, 11:30 pm | #46 |
No Longer a Member
2nd May 2019, 12:34 am | #47 | ||
Back in era when valves were the only choice for the active devices, in general there appeared to be more engineering rationality in respect of their application. In those days, suspension of disbelief was reserved for the opera, and not extended to the mathematics and physics of amplifier design. With hi-fi amplifiers, push-pull outputs were generally used where outputs upwards of 10 watts were required, whereas the smallest units, up to around 3 watts, were usually single-ended. In between 3 and 10 watts, both types were found. Valve availability may have been a part of this. Also, a reasonable inference is that at around the 10 watt level, an EL84 push-pull pair generally offered better economics than say a single-ended KT88. There were some variations though. For example, Pye used a single-ended EL34 output in its Mozart amplifier. One may impute a possible engineering reason for this, in that it may have been the best way to fit the unit into what was, for the time, a very compact case. An EL84 push-pull pair plus an additional valve envelope for the phase-splitter might not have fit so well. This amplifier predated the availability of the ECL86, which once it was available offered another pathway to a compact amplifier, in that two valve envelopes encompassed driver, phase-splitter and output pair. By way of another example, the Heathkit MA5 used a single-ended parallel EL84 pair. This looks to have been an appropriate engineering solution for a minimum-valve count economic 5 watt amplifier, and not an initial condition. Early in the stereo era, there was some use of the orthogonal circuit. That too can be seen as an engineering solution, and was probably seen – by those who used it – as the most effective way to use two output valves where that was all that could be afforded. An interesting case was the Lowther B5F, made from 1948 through to the early 1950s, and which used a single-ended PX25. It was apparently a derivative of the pre-WWII B5, and I’d guess that the “F” suffix indicated that it had negative feedback applied. Post-WWII Lowther was in the hi-fi business, so the B5F was almost certainly designed as a hi-fi amplifier, and not a combination amplifier and coloration machine. Its 5 watt output was seen as adequate for driving horn-loaded speakers in some situations. And given that Lowther used a PX4 push-pull pair for a contemporary 7.5 watt amplifier, and a PX25 push-pull pair for its 15 watt amplifier, one may deduce that a single-ended PX25 was seen as the logical engineering choice for the 5 watt case, and that the single-ended configuration was not an initial condition. Single-ended transistor amplifiers are a rare species. The major application appears to have been in early hybrid car radios, where for example a single OC16, with transformer-coupled input and output, and without NFB, was used. Strangely, this configuration has yet to develop a latter-day cult following, even though it has some of the required credentials. Cheers, |
2nd May 2019, 2:31 am | #48 | |
No Longer a Member
Have you heard of Synesthesia ? I don't posses it, but wish I did, I'm sure this would help with the appreciation and creation of music: Synesthesia is a condition in which one sense (for example, hearing) is simultaneously perceived as if by one or more additional senses such as sight. Another form of synesthesia joins objects such as letters, shapes, numbers or people's names with a sensory perception such as smell, color or flavor. The word synesthesia comes from two Greek words, syn (together) and aisthesis (perception). Therefore, synesthesia literally means "joined perception." I know somebody with this and it is quite astonishing and very difficult to understand or quantify with math and physics. Creative and artistic folks have synesthesia often it would appear (isn't it horrible to be left out). On the Class A OC16, I must confess to liking this arrangement as you can see from my radio: http://worldphaco.com/uploads/THE_EF98-OC16_RADIO.pdf Last edited by Argus25; 2nd May 2019 at 2:56 am. Reason: typo |
2nd May 2019, 6:54 am | #49 |
I enjoyed Synchrodyne's excellent post. It needed saying.
In order to be fashionable, a single-ended amplifier must not only be single-ended, it must also LOOK single-ended. So a single-ended amplifier with an active current source providing the power supply current path looks push-pull to those who don't understand circuit design, and so would be seen as unfashionable. What is fashionable is unfathomable What is fathomable is unfashionable A perfect EXOR situation. David
2nd May 2019, 7:13 am | #50 |
This is an interesting topology that I came across some years ago. It is not single ended, but it is transformer coupled.
http://www.susan-parker.co.uk/zeus.htm Craig |
2nd May 2019, 8:44 am | #51 | |
2nd May 2019, 8:51 am | #52 | |
No Longer a Member
It is not uncommon in early Japanese transistor radios that the emitters of the two output transistors drive the output transformer primary, but to get gain in those cases the drive voltage from the driver transformer is applied to the base-emitter circuits of each transistor and are not significantly affected by the voltage developed across the load in the emitters, so it has no effect that the load is in the emitters, it may as well be in the collector in that case. If you are driving a base-emitter junction with a transformer, and say its a pnp transistor (in a negative earth system) its handy because you can bolt the collector to ground, avoid insulators, and put the load in the emitter instead. |
2nd May 2019, 9:01 am | #53 |
Hybrid Car Radios often used a similar circuit arrangement to that in the link in Argus25s post, where an OC16(later AD140 or 149) was driven from a low-voltage operated valve.
2nd May 2019, 10:09 am | #54 | |
You can adjust the bias very slowly to overcome the thump, but then you get distortion for longer periods. You could of course have a delay in the system so that you can change bias in anticipation of a sudden increase in signal in a few seconds time, but that's adding massive complication (audio storage, tape loops? Bucket-brigade delay lines? ADC - buffer memory - DAC? All horrors!) |
2nd May 2019, 10:19 am | #55 |
Does that mean you need an exorcist to take care of audiophools?
2nd May 2019, 11:05 am | #56 | |
No Longer a Member
2nd May 2019, 11:42 am | #57 |
I keep saying they ought to declare themselves as a religion. There are tax advantages, I understand, and at the prices of their icons, that could make a big difference.
2nd May 2019, 12:26 pm | #58 |
He did. The margaritas might have helped though.
2nd May 2019, 2:09 pm | #59 |
Hardly! Every early Sony Trinitron colour TV had one up to the mid 70s and they were not alone; Hitachi used this topology too, as did many other Japanese manufacturers. BRC also used this method for the very popular for their 8000 series sets. That lot alone encompasses millions of individual pieces of equipment.
In an early transistorised colour TV set there was usually a DC supply of around 115V which was stable, so long as you didn't take random gulps of current out of it. A transformer coupled singled ended audio output stage was therefore ideal for the 1 > 2W of audio output that was expected. |
2nd May 2019, 2:39 pm | #60 |
Meawhile, the Audio Note Kagura https://www.audionote.co.jp/en/produ.../kagura-i.html
Which will set you back £150k. Craig |
