21st Mar 2019, 8:25 pm | #1 |
Identification of Sobell radio?
I'm considering bidding on a Sobell woodie/wood-effect radio in a local auction, it looks nice and original but the type sticker is partially missing. It's a Type 51??
From what little I've found I think it may be a later 516 but unsure, no other 51x I have found online looks similar. Photo is of the actual radio. Thanks in advance for any guidance, Dan. |
22nd Mar 2019, 4:28 am | #2 |
Re: Identification of Sobell radio?
It's a Model No 599.
There is a little discussion about it here- https://www.vintage-radio.net/forum/...d.php?p=963914
Clive |
22nd Mar 2019, 11:15 am | #3 |
Ah, the damaged label definitely states 51xx so I imagine it's at least had the back panel replaced, not so nice & original/unmolested then & I gather it'll be AC/DC, still a nice looking set and looks plenty of room for dropper heat dissipation. Not a lot of info about on it but I may have a stab at it, will see what the bidding goes like, it's up this morning so will report back later what happens.
Thanks. Last edited by ekjdm14; 22nd Mar 2019 at 11:24 am. |
22nd Mar 2019, 1:49 pm | #4 |
OK I have bought the Type 599 and also a Bush SAC35, so will post more photos and seek info when I collect them along with a good few later things including a Thorn EMI VCR for a fiver
Not a great deal of info easily found online so far though, guessing Sobell were not as well known/large in the first few years in business? (I'm guessing the set to be late '40s and I believe Sobell was registered as a company in '46). |
22nd Mar 2019, 2:03 pm | #5 |
Some info on Sobell Here
https://www.gracesguide.co.uk/Sobell_Industries The picture of the 519 looks a lot like your set. Cheers Mike T
22nd Mar 2019, 2:36 pm | #6 |
Ah that would make sense yes, at least the back could tally with the actual set now Just having a brew then off to collect my spoils.
Thank you for the link, some good info on the company there. |
22nd Mar 2019, 3:39 pm | #7 |
Variation of the 516?
22nd Mar 2019, 3:41 pm | #8 |
duplicate
24th Mar 2019, 1:55 pm | #9 |
Right, small update now I've got over the shock of finding myself in need of a unicorn-fart valve for another set!
Back off this set (indeed it is a 519P, thanks for the link Mike) and it looks more promising to not be "got at". Full of fluffy dust over everything and no sign of tampering. Will shove the Bush Audiocentre 1500 off the workbench in rude fashion and get cleaning in a moment. Much more hopeful of a faster result with this set, and it looks just as lovely as the Bush but in it's own way. Cheers, |
24th Mar 2019, 5:11 pm | #10 |
I was beginning to think I got my model numbers mixed up so I just dug out my Dad's copy of Radio And Television Servicing to see if they are indeed variations of the same set.
It fell open at a well used page 554 covering the 519 so that is probably the model that I grew up with. The 516 is on page 564 and apart from a few minor changes they are both basically the same. Same valve lineup, layout and both feature band pass tuning on M.W. According to the back covers both sets on the bookcase behind me are 516's |
24th Mar 2019, 11:24 pm | #11 |
I still haven't got round to taking photos of either of my latest purchases, which I really should. But the good news is, the Sobell is now officially back in the land of the living having received it's ceremonial replacement power cord and run on the RCD for a few minutes.
I had most of the caps in stock, although I had to make up one of the .1's for the moment & I will need to attend to the electro' cans as one is open on both sections although the other has reformed nicely. Obviously don't want to run the set more until that's attended to but it appears very sensitive and selective on all bands, particularly SW as it picked up a Romanian broadcast & this is just with a floating bit of old flex as an antenna. Give it a proper long wire and earth I'm sure it'll be quite a little performer. It'd make sense that they were basically very similar, if they had something that worked this well I can imagine them being loathe to change too much. Next few days I'll get the electro' cans attended to & then look towards giving the cabinet a deep clean and polish up before bringing it upstairs and letting it run a while. Edit- my guess of late '40s seems to have been correct, some of the old caps were dated 1949... Last edited by ekjdm14; 24th Mar 2019 at 11:29 pm. |
