6th Apr 2014, 4:25 pm | #21 |
Re: Rainy day with some TV valves
6th Apr 2014, 4:29 pm | #22 |
5Y3 from the data sheet.
Horizontal operation allowed if pins 2 & 4 are in a vertical plane. Tubeglow. |
6th Apr 2014, 4:53 pm | #23 |
"sweep tubes" was designed to working around 16kHz
6P45C from Russian colour TV up to 90W from pair |
6th Apr 2014, 5:07 pm | #24 |
I expect that the directly-heated types with long, thin ribbon cathodes could suffer long-term from gravity's depredations if unsympathetically orientated- the 5Y3 being a prime example. Many who've used the AR88 will know that they can get surprisingly fragile with age.
6th Apr 2014, 5:18 pm | #25 |
They happily go way, way beyond that: us radio-amateur types happily run them up to 21MHz (or 28MHz with slightly reduced performance) in grounded-grid service.
You can push a single 6LF6 to 175-watts PEP. It's rated for 40-watts continuous anode dissipation, temporary overload of 200 Watts. I'd say a single PL519 should deliver 150W PEP out without being unduly stressed. Google "Skinnier Linear" for more details. |
6th Apr 2014, 5:27 pm | #26 |
6th Apr 2014, 8:42 pm | #27 |
Keep say how good the PL5 range is and it will become the next PX4 with mega price to match.
6th Apr 2014, 9:19 pm | #28 |
Probably a good valve for instrument amp use, but very non linear when driven by G1.
It does work well when driven on G2, but then it needs more drive and drive must be at about +130v !!! Ed |
