Old 25th May 2020, 10:28 am   #21
Station X
Station X's Avatar
Default Re: Watt Torino - Cadetto Repair
We have the correct cap at last then. Looks easy to replace.
Graham. Forum Moderator
Station X is online now
Old 25th May 2020, 12:34 pm   #22
real0real
Have just ordered new one, possibly take a week to arrive (the caps for the KB666 have arrived might start changing them).
real0real is offline
Old 25th May 2020, 12:44 pm   #23
Station X
Station X's Avatar
If you're planning on restoring several radios it might be worth buying capacitors in bulk.
Old 25th May 2020, 1:01 pm   #24
real0real
have noticed that capacitors are lot cheaper if purchased in bulk / assorted packs ,i am thinking of possibily restoring a few as enjoy doing ,but see how i get on with these as learning aswell
Old 29th May 2020, 5:16 pm   #25
real0real
Update
Today have changed the the audio coupling capacitor , plus fitted new power lead as old one was bit dodgy ,
With reference to changing the smoothing capacitors, probably located in the dual can , is the dual can a metal cannister as in picture attached ?
Clive
ID:	207130   Click image for larger version
Old 29th May 2020, 5:24 pm   #26
ms660
ms660's Avatar
That looks like a single capacitor, probably the reservoir capacitor, what value is printed on it?
Lawrence.
ms660 is offline
Old 29th May 2020, 5:53 pm   #27
real0real
Little difficult to see whats written on it but looks like following any idea?
UF 3.2
?? 350
?? 450
Pictures attached
Old 29th May 2020, 6:11 pm   #28
ms660
ms660's Avatar
If it's the reservoir capacitor then 3.2uF would be too low and 32uF would be too high according to the schematic, is it connected to one of the rectifier's heater pins? What rectifier valve is fitted?
Lawrence.
ms660 is offline
Old 29th May 2020, 7:18 pm   #29
Graham G3ZVT
Graham G3ZVT's Avatar
On the schematic, why is the cathode of the rectifier connected to one side of the speaker?
Graham.
G3ZVT
Graham G3ZVT is online now
Old 29th May 2020, 8:38 pm   #30
Station X
Station X's Avatar
There should be four electrolytic capacitors in this set. 2 X 6uF smoothers and 2 X 10uF cathode bypass capacitors. I can only see two and neither of them match those values.
I'm assuming that the 3.2uF is a smoother as it's close to the rectifier and mains transformer.
I'm also assuming that the speaker is of the energised type with the energising winding doubling as a smoothing choke.
Only way to be sure is to trace the wiring.
Old 30th May 2020, 11:16 am   #31
real0real
I have had a look to see which pin 3.2uF is attached to but noticed that the 80 Valve is listed as having 4 pins
https://www.radiomuseum.org/tubes/tube_80.html
where as the valve fitted has 5 pins ? so not sure which pin it is attached to have attached pictures , the pin it connects to does go to the transformer
ID:	207211   Click image for larger version
ID:	207212   Click image for larger version
ID:	207213   Click image for larger version
Old 30th May 2020, 11:25 am   #32
Station X
Station X's Avatar
That's not an 80 valve. What does it say on the label or perhaps on the envelope?
The valve and holder may have been changed either in production or as a modification.
The fact that the electrolytic cap is connected to the rectifier shows it's a smoothing capacitor.
Where does the other electrolytic cap (8uF?) connect to?
Old 30th May 2020, 11:32 am   #33
real0real
The valve fitted unable to decipher what it says / type have attached picture of
Old 30th May 2020, 11:47 am   #34
ms660
ms660's Avatar
The connections shown in the photo's tally up with a 5Y3G rectifier amongst others, that capacitor is definitely the reservoir capacitor as it's connected to one of the rectifiers heater pins.
The 8uF capacitor is connected across the main HT rail.
Lawrence.
ms660 is offline
Old 30th May 2020, 11:54 am   #35
real0real
attached couple of pictures of 8uf attached to central grid and feeds of from the other end
ID:	207220   Click image for larger version
Old 30th May 2020, 11:57 am   #36
Station X
Station X's Avatar
As Lawrence says it's connected across the HT supply, so the 3.2uF will be the reservoir cap and the 8uF the smoother cap.
I'd replace them both with 10uF.
Old 30th May 2020, 12:07 pm   #37
ms660
ms660's Avatar
If a loudspeaker field coil is used in the receiver then ideally it would be good to know what the peak AC voltage is into the rectifier so as to be sure what the voltage rating of the replacement HT electrolytics should be.
Lawrence.
ms660 is offline
Old 30th May 2020, 12:24 pm   #38
Station X
Station X's Avatar
Power has been applied to this set and "that" capacitor has been changed.
The OP could measure the AC voltage from chassis to pins 4 and 6 of the rectifier, then multiply by 1.41.
Old 30th May 2020, 12:30 pm   #39
real0real
can order 2 x 10uf as not have , both at 350v rating ? any others may need ordering ?
Old 30th May 2020, 12:35 pm   #40
ms660
ms660's Avatar
I would measure the AC HT voltage from the transformer with the rectifier removed, I don't like the look of that electrolytic.
Lawrence.
ms660 is offline
