Reply
Old 9th Nov 2017, 4:08 pm   #1501
TimLiggins
Default Re: AVO Multimeter survey
AVO 8 III 80197.568 just arrived today
TimLiggins is offline   Reply With Quote
Old 9th Nov 2017, 10:48 pm   #1502
The Philpott
The Philpott's Avatar
s/no given by Tim (and taken in conjunction with others) indicates that in 1968 some 1,000 Model 8's per month were being completed.
The Philpott is offline   Reply With Quote
Old 10th Nov 2017, 9:22 am   #1503
ex 2 Base
Peter,pmmunro and others, got the image size sorted, daughter arrived and of course they/she new straight away.Ted
ex 2 Base is offline   Reply With Quote
Old 10th Nov 2017, 10:29 am   #1504
TimLiggins
Sadly, my newly acquired Model 8 III has a broken hairspring in the meter movement. Presumably this is not a viable repair unless I can find a replacement movement. The instrument appears to be in superb condition otherwise.
Tim
Old 10th Nov 2017, 10:49 am   #1505
The Philpott
Broken is a problem (sure it's broken not just tangled..?)
An old school watchmaker would have the steady hand and skills (but it would be expensive and you would have to provide the replacement spring) so i think the movement is a goner.
If all the tiny leaf switches inside look good, and all the shunts show correct resistance, it is well worth fitting a movement from another meter. (tatty meters for sale often have a good movement and can be used as a parts donor)
As Pete has said before, beware of using the 'old' scale plate on a 'new' movement as there are different scale shapes and the number at the bottom must match. (it is often a 5 or a 6)
Much better to keep the movement and scale plate together, although to the purist this gives the meter a new serial number (Hasn't stopped me in the past!)
Above all do not be disheartened since in my experience most Model 8's on general sale will have a gremlin of some sort.
Old 10th Nov 2017, 10:54 am   #1506
The Philpott
Additional- if in fact the spring has come de-soldered at one end it is viable --but fiddly-- to try and re-solder it.
I think Peter Vis' website has a few comments on this.
Old 10th Nov 2017, 10:57 am   #1507
Sinewave
Sinewave's Avatar
Can you take a photo of this please? There may be something you can do if it's the cut out spring which has hooked onto something else.
Sinewave is offline   Reply With Quote
Old 10th Nov 2017, 11:38 am   #1508
TimLiggins
Thanks for the replys. On closer examination the spring isn't broken, just tangled slightly. I'm struggling a bit to try and sort it since I'm waiting for cataract surgery. Now where did I put that magnifying glass?
Tim
Old 10th Nov 2017, 12:42 pm   #1509
TimLiggins
I've come to the conclusion that someone else has had go at this and has irepairably distorted the spring. Tried to take photos but without success. Given the condition of the rest of the meter I shall look out for a spares donor. Is the meter movement unique to the mark 3 or interchangeable with 1 and 2s?
Tim
Old 10th Nov 2017, 1:02 pm   #1510
Sinewave
Sinewave's Avatar
I'm told the meter movement scales are 'calibrated' to the device itself, they were printed to suit the characteristics of the meter.
Situations like yours is why if I'm buying something from that auction site, I'll ask if it is working or not and bid accordingly.
Similarly a lot of sellers there don't even know what it is they're selling.
Old 10th Nov 2017, 2:40 pm   #1511
The Philpott
I believe that an earlier Model 8 movement complete with scaleplate will suffice, the typeset/font is slightly different on the scaleplates, but still good and easily legible.
I don't believe a movement transplant will cause you calibration problems as such, a minor tweak on the magnetic shunt might be required to compensate for ageing if the donor meter has been sitting gathering dust for decades.
Old 16th Nov 2017, 11:50 am   #1512
philthespark
Hi All, sorry I've not been here recently, bit busy at work. Well here,s the pictures, and one of a rather weird piece of AVO kit, I've only ever seen one before. The 3 large AVO's are a model7, model 40, and the other I haven,t worked out yet.
ID:	152338   Click image for larger version
ID:	152339   Click image for larger version
ID:	152340   Click image for larger version
ID:	152341   Click image for larger version
philthespark is offline   Reply With Quote
Old 16th Nov 2017, 11:54 am   #1513
philthespark
the rest
ID:	152345   Click image for larger version
ID:	152346   Click image for larger version
ID:	152347   Click image for larger version
Old 16th Nov 2017, 9:01 pm   #1514
Phil G4SPZ
Phil G4SPZ's Avatar
The weird piece of AVO kit is an "AVO Test Bridge" which measures resistance and capacitance. I have one, and the circuit if you need it.
Phil
Phil G4SPZ is offline   Reply With Quote
Old 16th Nov 2017, 9:46 pm   #1515
philthespark
ah many thanks, someone told me it was for measuring power factor, I don't think I'll use it, it's just for looking at.
To be honest in my day job I use a Fluke multimeter, it's a bit more compact, but I still like the old AVO's, I'm trying to get hold of a reasonably priced model 8, the last type they made, I did have one, but when I was out of work with health problems it was one of the things that had to go.
Old 16th Nov 2017, 9:59 pm   #1516
philthespark
Originally Posted by The Philpott View Post
Continued-
1- more detail of instruction plate
2- instruction plate
3- improved image of front
4- scale plate detail. labelled 'Type 3' which is probably the scale shape.
There was a lot of (high resistance) verdigris and dezincification inside the wander plug ports, and one test lead had actually verdigris-ed through completely. This, together with the 25v bobbin being o/c, may have led to the meter being deemed useless and thus being converted into summat else.
New 3d printed feet are good, as is sometimes the case a thin sliver had to cut from one side of the rear ones, to avoid them catching on the instruction plate as it is opened. (A problem that could arise with the original feet.)
If anybody ever has the wish and technology to make a few Model 1A scale plates from worn out Model 1 plates, by all means PM me and get a better image from me on email, (but send me a couple of examples when they're done, eh?!)
Another meter saved, anyhow!
Dave Philpott
May I say how nice it is to see your restoration, I may get around to doing mine soon. It upsets me to see this current steampunk craze for butchering old meters and turning them into lamps, a meter that has survived over 50 years as a meter, will probably end up being thrown in a skip within a year of being converted to a lamp! Why oh why can't people just clean them up and admire them for what they are, after all they don't convert old books into lamps do they!
Old 17th Nov 2017, 11:43 am   #1517
The Philpott
Thanks Phil. Fortunately the two components that marked that Avominor out as a 1A hadn't been touched so survival of the concept was assured even if the remaining parts had been ruined. The craze for 'the industrial look' has taken it's toll but as is the nature of fashion i hope it will fade one day.
(There was a conversion of the universal avominor back in the day, to a 'protometer' which was a conventional damp meter, retaining the movement and (modified) scale and blocking up most of the terminal ports.)
It's surprising how quickly those wander plug terminals fill up with dust and fluff, which then has the annoying habit of dulling the brass. Looks like you'll have to get in there with a cocktail stick and air pressure on yours!
Dave Philpott
Old 19th Nov 2017, 6:32 am   #1518
noble kiwi
Kia ora Dave,
It has always i.e. previously been my opinion that plugs and sockets must prove superior to a sector switch. Recent comments have stirred up my thoughts.
This is certainly an interesting site.
Trevor, from way down under.
noble kiwi is offline   Reply With Quote
Old 19th Nov 2017, 12:50 pm   #1519
The Philpott
Yep Trevor, you can certainly tell the wander plug instruments that haven't been kept in their box while out of use; i have a meter that has been boxed most of it's life and the terminals are as bright as granny's candlesticks!
I reckon survival of wander plug instruments has benefited from the good old 'lack of moving parts' phenomena. There is an additional glitch with the early avominor in that the terminals aren't always smooth and parallel along their length (possibly due to the peening) so nothing short of a miniature brass bottle brush or a pipe cleaner coated in abrasive polish is going to clean properly.
One thing i have noticed is brass suffering from zinc migration can't be relied upon for good conductivity- even if it's polished to pretty pink.
Dave
Old 14th Dec 2017, 11:18 am   #1520
coil1234
Recently acquired another Avo.
Model 8X (Panclimatic) in reasonable condition.
Ser No 169223-C-964 so looks to be Sept 1964 manufacture.
Regards
Mike Andrews.
coil1234 is offline   Reply With Quote
Reply
