Reply
Old 23rd May 2024, 5:43 pm   #1
vinrads
Default 1930's Ferguson radio
This radio was gifted to me by John (old John) after replacing all the paper capacitors, output TX and HT choke/speaker energising coil the set came to life. At this time I didn't have a circuit, which left me wondering what these strange looking things were which didn't read anything. Having then received a service manual, a big thanks to Dave (G6ONEDave) I discovered they were low voltage cells. Note this radio was built in 1938. I have fitted two E cig batteries and a resistor to obtain 5.5 volts. My next job is to re align the set.
Mick.
Name:	IMGP0003 - Copy (2).jpg
ID:	297933   Click image for larger version
Name:	IMGP0005 - Copy (2).jpg
vinrads is offline   Reply With Quote
Old 23rd May 2024, 7:12 pm   #2
Station X
Station X's Avatar
Default Re: 1930's Ferguson radio
Grid bias batteries which don't have to supply any current.
Graham. Forum Moderator
Station X is offline   Reply With Quote
Old 23rd May 2024, 7:26 pm   #3
60 oldjohn
Default Re: 1930'S Ferguson radio
Hi Mick, Pleased you are making progress with the radio. Strange the Grid Bias battery, I had an Ambassador radio that used a D cell (HP2) Grid Bias supply. I suppose it would give the repair shop a job when it failed possibly many years ahead (Shelf Life) as no current would ever be used as long as the capacitors were in good condition.
John.
My favourite text message "I'll be there in five minutes, if not read again"
60 oldjohn is offline   Reply With Quote
Old 24th May 2024, 11:00 am   #4
Silicon
Those Mallory Bias Cells were available in 1 Volt and 1.25 Volt versions.
Some restorers inject a little water into the cells with a syringe to re-activate them.
Silicon is offline   Reply With Quote
Old 24th May 2024, 11:43 am   #5
Nickthedentist
Nickthedentist's Avatar
That's a new one on me. Heard of them but never come across a set which employs one.
What's the Ferguson's model, Mick? The only one I have here is the 501AC from 1937.
Nickthedentist is offline   Reply With Quote
Old 24th May 2024, 12:55 pm   #6
vinrads
Hi Nick it's a Ferguson 773 motor tuned , 5.5 volts is applied to a 6j7 which acts on the osc to keep stability when on auto tune . Mick.
Reply
