Reply
Old 26th Apr 2024, 7:16 am   #1
tv baron
Default Bush TV22
Hi bit of help on line stage i dont have an eht meter i get a nice arc of one side of the ey5i on coil c but not a lot to tube the heater is lit on the ey51 do the over winds go faulty coil f thanks
tv baron is offline   Reply With Quote
Old 26th Apr 2024, 12:30 pm   #2
Freya
Freya's Avatar
Default Re: Bush TV22
EY51`s go bad, their leads have a habit of dropping off at the pinch. But the overwinds also do suffer from both saturation and shorted turns.
Stephen
Freya is offline   Reply With Quote
Old 26th Apr 2024, 7:16 pm   #3
Sideband
Sideband's Avatar
There is loads of information on the LOPT's within these forums. It will probably benefit from drying out and the preferred way is to pass a small current through the overwind so that it gets warm (not hot) for several days.
Try doing a search TV22 LOPT or Bush LOPT
Sideband is offline   Reply With Quote
Old 29th Apr 2024, 8:03 am   #4
mark pirate
mark pirate's Avatar
Well worth drying out the LOPT, these have a habit of developing shorted turns.
I always fit a new EY51 to any set I restore, usually increases EHT by 1 to 2 kv.
Mark
mark pirate is offline   Reply With Quote
Old 10th May 2024, 6:55 pm   #5
tv baron
Default Bush tv22
Hi now starting to go round on caraculs have a set wit no raster but sound the brightness pot with about 100 volts get spark of over wind ey51 lit no eht probe but put avo on 3kv on final anode went right over on the metrosil to a1 on transformer side 250 volts other side to tube15 volts suspect transformer winding but not sure any help thanks
Old 10th May 2024, 7:06 pm   #6
HamishBoxer
HamishBoxer's Avatar
Default Re: Bush tv22
I would not put an AVO on final anode! Could be higher with correct set up, trust Ion Trap is in the right spot?
HamishBoxer is offline   Reply With Quote
Old 12th May 2024, 8:49 pm   #7
tv baron
Hi have now got EHT but low A1 volts sorting out to 100 volts give raster but low volts from the Metrosil what can I replace it with
Old 12th May 2024, 9:19 pm   #8
FRANK.C
FRANK.C's Avatar
If I remember correctly there is a sneaky wax paper capacitor hidden under the tagboard that can drag the A1 volts low.
Frank
FRANK.C is offline   Reply With Quote
Old 12th May 2024, 9:57 pm   #9
tv baron
Thanks Frank spot on now have a raster well hidden I'd changed all the others but you cannot see it thanks for info one step closer
Old 22nd May 2024, 12:22 pm   #10
tv baron
Hi have now got a signal to it and a hedgehog test card can lock frame between two half's and mods out there for frame stage thanks
Old 22nd May 2024, 4:24 pm   #11
tv baron
Default Bush tv22 frame o/p
hi having problems frame will lock but two half frames are there any mods out on this old lady thanks
Reply
