Reply
Old 3rd May 2024, 6:37 pm   #301
ScottishColin
Default Re: Commodore 8026 printer / typewriter
It is a 327 on this board.
I'm struggling to read the capacitors though - they are going the same way as the others.
J1 is top left of the picture - 16 way connector with 4 pink, 4 yellow and 4 black. There's an extra connector on this board - on the right hand side of the main board with a black and purple cable. It looks at first sight that it comes from the PSU. There's also a connecting wire from the 39V point on the bottom right on the main board to the daughterboard (brown wire) which is not on the Commodore version.
Colin.
Originally Posted by SiriusHardware View Post
The battery leak damage to the components just north of the batteries doesn't look quite as bad as on your original machine, so there's some hope that you might be able to read the number off what we've been calling the '327' to see what it actually is - also the values of those capacitors near the power input connector.
I notice there is indeed a serial UART IC (6850) just where Tony suggested there could be one.
Is the J1 connector you've been talking about the long black connector at the far left end of the upper edge of the PCB?
ScottishColin is offline   Reply With Quote
Old 3rd May 2024, 7:09 pm   #302
SiriusHardware
Good to have the identity of the mysterious transistor confirmed once and for all, and a good call by all who suggested it might be a BC327. Shame about the caps but as originally said the value won't be too critical as long as they are appropriately voltage rated (which the ones you fitted in the other machine are).
If you were able to desolder one end of each of the different types of capacitors near the power input connector your new component tester box would tell you their values, but maybe wait until the desoldering iron arrives if you want to try that.
OK, 16 way, and what pin spacing? Pull the connector off and line up one side of a larger DIP IC next to the pin row connector, is the pin spacing the same as the pin spacing on an IC?
SiriusHardware is offline   Reply With Quote
Old 3rd May 2024, 7:18 pm   #303
SiriusHardware
It occurs to me that if the J1 wiring loom is the same at both ends in both machines, you could 'borrow' the loom from this machine and fit it in the 8026 if you think the condition of the contacts looks any better.
Old 3rd May 2024, 7:21 pm   #304
ScottishColin
This is a photo from the Commodore 8026 where I was playing with the idea of replacing the connector with individual DuPont connectors and soldering them to the wiring of the motor itself. I'd label them individually if I did this - hopefully that answers the question below.
Colin.
Old 3rd May 2024, 7:22 pm   #305
ScottishColin
Yes - that was my thought too. I'll check the state of the connector/contacts.
Colin.
Old 3rd May 2024, 7:29 pm   #306
SiriusHardware
Re: #304, that suggests to me that they are 0.1" (2.54mm) pitch, which is one of the most common. Not long ago I could have instantly found you a polarised 16-way pin-row connector and a matching connector shell and crimp contacts but I don't think we have any left now.
I get the impression you are fairly determined to avoid having to change that connector pair so I guess you'll probably try swapping the cable loom, if possible, first.
Old 3rd May 2024, 7:40 pm   #307
ScottishColin
The issue is that my confidence has decreased in my ability to desolder, particularly repeatedly, on these older boards.
My desoldering station has turned up but been whisked away from under my nose and given to my Mother-in-Law to give back to me on my birthday in 3 weeks or so. I'll try the other one first I think.
Colin.
Old 3rd May 2024, 7:53 pm   #308
Mark1960
Its possible to get housings in multiples for dupont connectors, and you can release the contact from the singles and fit into the multiway connector so you don’t need a crimping tool.
https://www.aliexpress.com/item/1005006208001550.html
Mark1960 is online now   Reply With Quote
Old 3rd May 2024, 9:24 pm   #309
ScottishColin
I've got a crimper and some 4/5/6/7 way housings which I can use.
I just need to stop prevaricating and make a decision...
Colin.
Old 3rd May 2024, 9:48 pm   #310
SiriusHardware
As you are in the hitherto highly improbable position of possessing an identical(?) spare cable loom I would probably try that first, as long as you are sure it is wire-for wire, point-to-point identical to the one on the 8026 - bearing in mind that they are not identical devices.
Old 4th May 2024, 2:29 am   #311
ortek_service
ortek_service's Avatar
Colin.
Well the white connector on the photo attached to that (#304) post, has an unusual latching tab at the top of one of the long sides and is similar to those used in older TV's - but usually with a rather-larger pitch (particularly with ones on HV scan-coils)
It isn't clear if the 16w black J1 one is a similar one, especially with all those individual sockets inserted.
- Did you ever find any markings on the original 16way socket-housing?
A photo of that may be usefu to help identify it.
Plus taking a look at this useful website, to see if there's one that looks the same: https://www.mattmillman.com/info/crimpconnectors/
ortek_service is online now   Reply With Quote
Old 4th May 2024, 4:31 am   #312
TonyDuell
Colin.
My guess is that that carries one or both of the +/-12V supplies for the RS232 driver. Or some voltage they could be produced from.
TonyDuell is offline   Reply With Quote
Old 4th May 2024, 10:22 am   #313
ScottishColin
OK - photo attached of the two motors which are marked slightly differently, although the connectors/wiring are the same.
The left hand motor marked "2x380/0,236" is the original Commodore motor. The right hand motor marked "2x370/0,236" is the one from the Olympia printer.
I have plugged in the Olympia motor to the Commodore printer and attached all other connectors.
At power on, I get a short beep every time.
About 50% of the time, the motor in question is free, 50% of the time I get a small movement then it locks.
Colin.
Old 4th May 2024, 11:26 am   #314
ScottishColin
Additionally, none of the keys produce any activity. Also moving the print carriage manually to the left still triggers the sensor correctly which then triggers the motor in question correctly.
Colin.
Old 4th May 2024, 12:18 pm   #315
TonyDuell
When you say 'triggers the motor in question correctly', what do you mean? The motor runs? The motor locks?
Old 4th May 2024, 12:24 pm   #316
ScottishColin
The motor runs in a consistent direction until I move the carriage slightly to the right manually.
Colin.
Old 4th May 2024, 12:43 pm   #317
TonyDuell
Well, that means the motor driver transistors and the processor are all working, otherwise the motor could not turn.
Old 4th May 2024, 1:12 pm   #318
ScottishColin
I assume it also means that the optical sensor on the small PCB on the carriage is working too, along with (at least some of) the cable connecting the carriage PCB to the main board.
Colin.
Old 4th May 2024, 1:39 pm   #319
TonyDuell
Yes, it must be detecting something.
Is this in the Commodore unit?
I think you need to repair that broken gear. Is there a good one in the Olympia typewriter that you could borrow. For a more permanent repair I'd probably get a gear of a suitable type (this was discussed many messages ago) and make a spindle/hub to put it on, but it is likely you'd need a lathe. You've suggested 3D printing, which may well be worth a try.
Old 4th May 2024, 1:47 pm   #320
ScottishColin
It is the Commodore unit.
The 'new' Olymipa gear has the same problem sadly.
Right now, the motor connected to J1 is out of the printer so it is not affected by the broken gear but I agree, I need to make one.
Colin.
Reply
