#261 |
I think a base-collector short in the associated transistor would give the odd readings. 0.6V or so when the diode is forward biased. And the b-e juncton + the clamp zener ('backwards') gving 2 diode drops or 1.2V when the diode in question is reverse-biased
#262 | |
![]() Quote:
Please remember I don't own such a printer and have never seen one working, so I have no more information than you do |
#263 |
You have vastly more experience with, and understanding of, 'hybrid' electronic / mechanical gear than I do. My experience tends more towards the purely electronic.
I'm trying to decide whether the input from the 'home' sensor actually disables / enables the multivibrator or only alters its frequency / pulse width. The 'missing' 10K collector resistor for Q3 is presumably present in the form of an internal pull-up on the INT pin of U9. Maybe the INT input triggers on a falling edge and the multivibrator is there to make sure it definitely sees at least one falling edge when the 'home' position is reached. I also considered that it might be a one-shot, (monostable) to generate a reliable single pulse of known width when the home sensor 'detects', but with the two 4n7 caps rather than just one, it looks more like an astable. None of this matters much as long as the INT pin sees one thing when the carriage is 'homed', and another when it is not. |
#264 |
That's why I asked Colin 'what do you see on the INT/ pin'. Provided there are 2 distinct signals, one when the carriage is home, the other when it's not, it's likely the sensor is working correctly.
I am happy to carry on contributing to this thread and to give my thoughts. All I was sayig was that they are just my thoughts/deductions from the circuit diagrams, etc. Not actual measurements from a working unit. And I most definitely make mistakes! |
#265 | |
![]() Quote:
Colin could, I suppose, remove it and try it on his new fangled tester box: Then try the same thing with any one of the other three to see whether it reads / tests the same or differently. |
#266 | |
OK - due to either
a) my ineptitude or b) the diode being old and knackered (I'm going with a and sticking to it) the diode has come apart. Please can someone let me know what diode I need to replace it with? Thanks. Colin. Quote:
#267 |
It would be unusual for a plastic diode to just fall apart like that so maybe it really was faulty, although see Tony's insight (#261) into a possible problem with the associated transistor, and not the diode after all.
Are there any numbers readable on the other diodes? They will all be the same. The good news is that these will just be ordinary silicon rectifier diodes so anything with a similar voltage and current rating should do, but ideally you want to replace with like for like. |
#268 |
I found the link in post #109 to a place where the schematics for the underlying Typewriter are held: Unfortunately I can't unzip the schematic here at work, as we have nothing on our locked-down IT which will unpack 7zipped files.
Can someone have a look and see if the diodes in question (the ones connected to Q7, Q8, Q9, Q10 collector) are identified by type / part number on that diagram? |
#269 | |
![]() Quote:
#270 | |
![]() Quote:
Colin, can you post a photo of the diode in question and a still-intact one on the board, please. |
#271 |
Here's a photo as requested.
Colin. |
#272 | ||
I've zoomed in and I'm reading 1M6168?
Colin. Quote:
#273 |
#274 |
Colin, could you now do the diode test on the non-existant diode (!). What I mean is to use the diode test range on your multimeter and put the probes on the 2 pads the diode came from, both ways round. That's with the unit turned off and J1 disconnected, of course.
I have my suspicions as to what the readings will be but don't want to influence your measurements... |
#275 |
I remember using 1N4448 where the 1N4148 couldn’t handle the current, same size but marked yellow yellow yellow grey. It might be worth using as a replacement if you don’t already have 1N4148 available.
#276 |
The colour bands are the old way of marking those diodes, they are still in common use today, modern replacements more usually have the numbers 4148 printed on them but they are the same. Like Tony I am surprised at such a tiddly little diode being used for this purpose.
With the diode now well and truly out of the way the measurement he suggests should show whether his suspicion about the Darlington is correct. |
#277 | |
I cannot get a reading in either direction (ie Overload).
I have tested continuity onwards for both pads and that's OK so I believe that the readings are correct. Is that what you suspected? Colin. Quote:
#278 | |
![]() Quote:
At the moment we are probably back to suspecting the diode was in fact faulty, although that 1.2V reverse voltage is suspiciously close to what we'd expect from a double-diode. Order some 1N4148 diodes anyway, as you are obviously going to have to replace the damaged one. When the new one is in you can try that measurement again with the new diode in place, see what we get then. |
#279 | |
![]() Quote:
Well Vishay at least have identical max ratings for their 1N4148 & 1N4448's: https://www.vishay.com/docs/81857/1n4148.pdf https://www.vishay.com/docs/81858/1n4448.pdf - Makes you wonder why they make both of these, unless it is just to be a second-source for other manufacturers And they do also have separate datasheets (although on the 1N4148 type they say it is also electrically-equivalent to the 1N914) However, they do only give Vf at 10mA for the 1N4148, whereas they give Vf at 5mA + 100mA for the 1N4448. For both of these their max ratings include: Peak forward surge current tp = 1 ?s IFSM 2 A Repetitive peak forward current IFRM 500 mA Forward continuous current IF 300 mA Average forward current VR = 0 IF(AV) 150 mA - I always thought 1N4148's were only rated at 100mA continuous / average , so maybe Vishay make higher-spec ones? So it seems that if there are high peak-currents, then the max. average current rating is strangely half that of the max. continuous current rating. Not sure if 1N4448's are as cheap as 1N4148's (used to be <=4p each, and I've often bought packs of 100 for a £1 or so) But as diodes are normally rather cheaper than the postage, then it may be worth obtaining some spares for all the different types used in this equipment in case any others get damages / common ones are always useful for building various projects. Last edited by ortek_service; 24th Apr 2024 at 11:13 pm. |
#280 | ||
![]() Quote:
It just proves you should not assume things. Always make the measurement. I'd fit a new diode and then re-do the tests. |
