Old 10th Apr 2024, 9:22 am   #1
Phil G4SPZ
Phil G4SPZ's Avatar
Default Gents synchronous clock
The museum where I work as a volunteer has unearthed this small but very heavy Gents mains synchronous clock. It appears to have been designed to fit into, say, a control panel. The entire clock hinges outwards for adjustment and is held in place by a heavy cast iron ring. The glass is thick and bevelled. The clock looks like it would survive any physical assault!
Has anyone ever seen anything like it? The coil measures 4k so it should run.
Phil
ID:	296145   Click image for larger version
ID:	296146   Click image for larger version
ID:	296147   Click image for larger version
Phil
Phil G4SPZ is offline   Reply With Quote
Old 10th Apr 2024, 9:36 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Gents synchronous clock
Nice!
May have also started life recessed into wooden panelling or mounted on a circular wooden base hung on a solid wall.
I have a similar Gents one made for the GPO and another smaller Smith one.
I did some training at the 1930s QE hospital in Birmingham in the 1990s and there were lots of spots where the original Gents recessed clocks had been ripped out and a cheap quartz job nailed over the top.
Old 10th Apr 2024, 1:02 pm   #3
Phil G4SPZ
Phil G4SPZ's Avatar
Thanks Nick, that’s very interesting. I didn’t know that Gents had ever made synchronous movements. This one has three worm-and-wheel reduction stages driving the motion work. I now need to find a mains socket to fit…
We are actually looking for a clock to go in our 1950s Post Office, so I was interested to note that Gents had made clocks for the GPO. Any chance of a picture of your example, please?
Hospitals, now there’s a thought - could the clock once have been part of an operating theatre panel?
Phil
Old 10th Apr 2024, 1:15 pm   #4
Robsradio
Very nice, Gent made clocks to last, as they have done, I run a few at home.
Hopefully it will run ok, but if not, or it's difficult to start, the problem is dried grease on the motor flywheel.
The flywheel should move independently from the rotor and it's motion is limited by a spring.
Over time the oil and grease dry and seize the flywheel on the spindle and it no longer does it's intended job and results in difficulty starting the clock and random stoppages.
A degrease and lubricate and it will start first time, most times, and will run a treat.
I would probably attend to cleaning and lubricating the rest of the movement whilst apart.
R
Robsradio is offline   Reply With Quote
Old 10th Apr 2024, 1:22 pm   #5
Phil G4SPZ
Phil G4SPZ's Avatar
Thanks for that, Rob. The movement is somewhat similar to the later 1950s Ferranti types with the solenoid coil and worm reduction gearing, and the sprung flywheel looks much the same. It actually looks very clean inside and there’s no solidified grease anywhere. I’ll give it a test run and see how it goes.
Phil
