Old 19th May 2017, 10:42 am   #1
mole42uk
mole42uk's Avatar
Default Has anyone rewound a Sectric motor?
I have an early Sectric chiming mantelpiece clock which stopped. Upon investigation, one of the connecting leads fell out from the coil of the motor. Unfortunately it was the inner connection!
The wire is 0.002" enamelled copper (47swg?) and the enamel insulation appears to be sound. Given that my other two Sectric clocks have a different style of motor, what's the likelihood that I can unwind the one I have, reconnect the inner wire and rewind it?
Richard
Index:
mole42uk is offline
Old 19th May 2017, 10:54 am   #2
Leon Crampin
Default Re: Has anyone rewound a Sectric motor?
Rewind with a full bobbin of 30 SWG wire and run the clock from low voltage AC. Use a variac to determine the voltage at which the motor will start, then add 30% to get the running voltage. An old wall wart transformer will power it.
Leon.
Leon Crampin is offline
Old 19th May 2017, 11:34 am   #3
Nickthedentist
Nickthedentist's Avatar
I'm in the middle of doing a Magneta in the way Leon describes. I will report back when it's done and let you know how I got on.
Re-winding with the original gauge of wire (for direct mains operation) is almost bound to end in tears as it's incredibly thin and fragile.
N.
Nickthedentist is offline
Old 19th May 2017, 1:51 pm   #4
Boater Sam
You would never rewind it with the original reclaimed wire, its too thin to stand unwinding and rewinding.
I find anything much less than 38swg difficult to wind.
Boater Sam is offline
Old 19th May 2017, 4:45 pm   #5
Brigham
If the break is in the first couple of turns, it could be possible to unwind them, and make a new connection to the broken end.
Brigham is offline
Old 19th May 2017, 5:08 pm   #6
Mike Phelan
Mike Phelan's Avatar
There are at least two members here who will rewind your clock stator with 47 SWG wire.
Mike.
Mike Phelan is offline
Old 19th May 2017, 8:09 pm   #7
mole42uk
mole42uk's Avatar
As I said in the original post, the break is in the inner connection.
Richard
Index:
mole42uk is offline
Old 19th May 2017, 8:11 pm   #8
mole42uk
mole42uk's Avatar
C'mon, name names! I'm up for that.
Richard
Index:
mole42uk is offline
Old 19th May 2017, 11:23 pm   #9
murphymad
murphymad's Avatar
Hello Richard,
I can rewind your clock coil.
I am regularly asked for exactly this type of rewind and I am only up the road from you in Devizes Wiltshire.
I would use new modern wire of the original gauge so that you can run it as original.
PM me with you phone number if you are interested.
Mike.
Mike Barker.
murphymad is offline
