Old 24th Feb 2020, 8:52 pm   #1
Uncle Bulgaria
Uncle Bulgaria's Avatar
Default Farnell SB30/10?
Ahoy,
I have one of these I got at the Audiojumble. The current limiter appears to do nothing, and I was considering adding meters to it for ease of use.
I can find manuals for the L series, but I don't know how similar they are. The transformer is enormous and the National Express men were not happy when they insisted on helping me off with my bag despite my protestations.
"Do you know there's a weight limit?"
Thank goodness I'm slim.
Uncle Bulgaria is offline
Old 24th Feb 2020, 9:04 pm   #2
evingar
evingar's Avatar
Default Re: Manual for Farnell SB30/10?
https://rtellason.com/manuals/Farnel...owerSupply.pdf
Chris
evingar is offline
Old 24th Feb 2020, 9:21 pm   #3
Uncle Bulgaria
No sooner said...
Thank you, Chris. I was getting nothing for 'SB' in my searches so I don't know what the 'S' stands for. It appears the current limit is just that - a final overload limit not an adjustable one.
Old 1st Mar 2020, 9:12 pm   #4
Julesomega
Julesomega's Avatar
Default Re: Farnell SB30/10?
Thanks for that link, I only had a hand-drawn schematic. The guy also has several more Farnells, and a stack of other manuals which would be worth exploring.
Just in case anyone is interested what thay look like, here is the 20A version, which used to appear often on eBay, a good linear PSU for transceivers, though it would have to live under the table. A deep unit with handles, and you really need those handles.
- Julian
It's good here
Julesomega is offline
Old 1st Mar 2020, 10:39 pm   #5
evingar
evingar's Avatar
I used to have a 20A version - real doorstop and used to give a loud "thump" when power applied. I let it go when I got equipped with a couple of 1KW (AP1KW) Farnell Switch mode types that I plumbed in as a basic Lab +/- supply. More than slightly overkill !
Chris
evingar is offline
Old 2nd Mar 2020, 5:44 pm   #6
duncanlowe
Yep, the thump with a vague rattle, as the side and top/bottom panels were slotted into the frame and moved with the thump from the transformer. Used them over many years at work. While I was 'away' someone has seen fit to throw them away.
The Farnell (Wayne Kerr) switch modes are fantastic. Again first came across one at work, and at least that one is still in use. On my own purchased when there were a few ex MoD ones around on eBay keeping the prices sensible, I replaced all the Rifas as they are a known issue on these. At work, in spite of a few reminders, the guy that uses it regularly, knows best. I hope I'm not there when they let go.
duncanlowe is offline
Old 3rd Mar 2020, 1:50 am   #7
Uncle Bulgaria
Mine looks rather more rustic than yours, Julesomega! The batteries are 6V 421s for scale...
If I wanted a display, is it really as simple as plumbing in one of those V/A LCDs, or dual analogue meters? If they're arranged correctly they should show the feedback effect too.
I have been looking at flyback circuits so I could have a current limit. They seem quite simple, and there's plenty of room inside. Has anyone experience of doing this?
ID:	200115   Click image for larger version
ID:	200116   Click image for larger version
Old 3rd Mar 2020, 2:12 am   #8
Julesomega
Julesomega's Avatar
Farnell used type numbers very liberally so it should not be too much of a surprise to find that the SB series had both terminal block and binding post versions. The little DVM modules are wonderful, and with care you can separate the supply connection from the input connection so as to get them to work down to zero rather than to the point where they stop working. Current meter versions are available, but for 10A you really need an external shunt which are not so available
- Julian
It's good here
Old 3rd Mar 2020, 11:48 am   #9
Herald1360
Herald1360's Avatar
Do you mean "foldback" perhaps? "Flyback" I would associate with a type of switching psu.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is online now
Old 3rd Mar 2020, 11:52 am   #10
Uncle Bulgaria
Yes, definitely! All the Fs...
Old 3rd Mar 2020, 5:34 pm   #11
short wave
Post 7 looks like an earlier one 60s? possibly using PNP output transistors (OC xx)
post 4 looks like a later one 80s using NPN output transistors (2N3055)
short wave is offline
Old 3rd Mar 2020, 7:29 pm   #12
evingar
evingar's Avatar
I also have a 3KW one (AP3KW) - surplus to requirement but ebaying is problematic becuase to do shipping properly it would need palletising and crating. I doubt the average punter would swallow the charges.
All 3 of mine have had Rifa's replaced, small electrolytic caps changed and socketed devices soldered directly into the PCB's . Changing the Rifa's on the 3KW one was a right and involved complete disassembly.
The 2 1KW jobs I think probably came from your military source judging from the stickers on them. Both worked out of the box, but one failed PAT testing due to the dodgy Rifa's - it also had an early warning "aroma" which in my experience is rare - they usually just belch out smoke without warning
Chris
evingar is offline
