Old 19th Feb 2020, 3:41 pm   #1
Default PCB layer linking pins
All,
What are those small pins for linking PCB sides called. The ones that come as a length and you snap them off once inserted.
MM
Old 19th Feb 2020, 4:13 pm   #2
donutty
Default Re: PCB layer linking pins
'Rivet strip' ? I remember them but it seems not used much any more. Used a lot with Veroboard.
They call it 'Continuous Track Pin'
https://www.newark.com/harwin/t1559f...pin/dp/93K1019
Funny that they discontinued a 'best seller' ...
Last edited by donutty; 19th Feb 2020 at 4:15 pm. Reason: Update with manufacturer's name
donutty is offline
Old 19th Feb 2020, 5:20 pm   #3
Brilliant, at least I know what to look for now.
Old 19th Feb 2020, 5:42 pm   #4
Herald1360
Herald1360's Avatar
Hollow ones were called "griplets" when I worked at Racal in the '70s.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 19th Feb 2020, 7:56 pm   #5
Jon_G4MDC
Jon_G4MDC's Avatar
Aargh Griplets!!
Veropins we recall with much more fondness.
The ones joined together in a stick Harwin PCB Track Pins. for Eg
https://uk.rs-online.com/web/p/crimp...ctors/5488225/
Jon_G4MDC is offline
Old 20th Feb 2020, 3:54 am   #6
Terry_VK5TM
Terry_VK5TM's Avatar
Or through hole rivets (although not in a bar, individual pieces)
http://www.fortex.co.uk/product/favo...nical-plating/
The rivets are cheap enough, but the machine cost will curl your toes (they can be fitted with a hand punch and hammer).
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 20th Feb 2020, 10:53 am   #7
Herald1360
Herald1360's Avatar
Originally Posted by Jon_G4MDC View Post
Aargh Griplets!!
....__________
Old 21st Feb 2020, 6:08 pm   #8
G6Tanuki
G6Tanuki's Avatar
In my days doing transistor RF driver/low-power-output stages and needing to link the upper/lower copper on a PCB the through-hole, peened-and-soldered rivetty-thingies were always known as "Stags".
G6Tanuki is offline
