Old 26th Feb 2020, 6:54 pm   #1
Default Elegant Seven Mk II (R&TV Acton Ltd)
Has anyone still got a circuit or even better build instructions for one of these?
I've just pulled the tatty one I bought at Harpenden in 2014 out of storage. Hooked up 9V and after exercising the wavechange switch and volume controls a bit, off it went.
Herald1360 is offline
Old 27th Feb 2020, 9:59 am   #2
robinshack
robinshack's Avatar
Default Re: Elegant Seven Mk II (R&TV Acton Ltd)
Sorry I can't help you Chris.
However, back in the day, my uncle used to buy and make these to order as a small sideline. He really liked the sound and would not make any other model.
From him, that was quite an endorsement.
Rob
I am also interested in and collect 00 model railway. My avatar is Bruiser, he has cauliflower ears!
robinshack is offline
Old 27th Feb 2020, 10:29 am   #3
dolphin
Although yours is a Mk II here's the construction information for the Mk I which probably has some similarities. It fell out of a copy of PW! If its any use you're welcome to the original.
Max
dolphin is offline
Old 28th Feb 2020, 9:38 am   #4
davidw
davidw's Avatar
Slightly different diagram here. #3
https://vintage-radio.net/forum/showthread.php?t=78158
Dave G1AGK.
My perception is my reality!
davidw is offline
Old 28th Feb 2020, 11:16 pm   #5
Thanks for those snippets. The circuit for the Mk1 is similar but the other one looks spot on. The main differences circuit wise seem to be an aerial coupling coil in the Mk1 and neutralising components in the other. The neutralising bit seems illogical timescale wise but may have been just down to what cheap devices were available to R&TV. The actual internal layout of the Mk1 is very different too.
Mine has a real ragbag of transistors- a couple of AF117s with snipped screen leads for the mixer and first IF, then a really old looking round ended rectangular thing for the second IF followed by four GEC labelled red ones with odd S7 and the like markings in the AF stages. Someone (possibly R&TV themselves) has added a couple of 4R7 emitter resistors to the output pair. They are small WW types with one end in the PCB and the other connected in mid air to an emitter. I did find a comment somewhere online about output device failure prompting this mod when I was looking for any information.
Just in case anyone wonders about the aluminium angle in the top of the case, it's a bodge I have added to take out an upward bow which was lifting the slot in the top rear away from the flange on the rear panel which should sit in the slot to retain the panel.
Old 28th Feb 2020, 11:26 pm   #6
Rob
I can relate to that- the cases looked a bit amateurish and the scale plastic was rather flimsy but the set was a good performer of its type back in the day. I suspect the totem pole output removed the worst limitations of a too small output transformer, helping to give a better sound.
My experience with a few other R&TV kits was similar, function rather prevailed over form.
