Old 30th Jan 2020, 8:26 pm   #1
JUSTDAMO
Default Retro Bar Pump Light
Hello,
I have a few of these retro type bar pump displays, the one pictured is just an example.
The the electrical component slides out and there is a space for looks like a tiny light bulb..... as this would light up the display, this I am sure of as the display case is hollow inside.
The only trouble is I don't know what they are called and where I could get any from....? it looks like a fuse would fit in but it is a bigger size.
Just underneath there is a connector part for you to feed a wire and then attach a plug to the end - thus giving it power.
Can anyone shed any light on type of bulb and what they are called?
Thanks
ID:	198047   Click image for larger version
JUSTDAMO is offline   Reply With Quote
Old 30th Jan 2020, 8:42 pm   #2
Outrun_uk
Default Re: Retro Bar Pump Light
I'd try using some 12 volt car interior light type bulbs and feed it from a suitably rated wall-wart type PSU.
HTH,
Kev
Outrun_uk is offline   Reply With Quote
Old 30th Jan 2020, 8:42 pm   #3
merlinmaxwell
merlinmaxwell's Avatar
Festoon lamps, although not designed to fit fuse holders (they use end pips) they do. Fuse style lamps are available but quite rare. Festoons can be had for Halfords etc. probably in LED by now.
Old 30th Jan 2020, 8:50 pm   #4
wave solder
wave solder's Avatar
There was a tubular lamp that was often used as a courtesy light called a festoon bulb. whether it would fit that holder though is unclear.
wave solder is offline   Reply With Quote
Old 30th Jan 2020, 9:09 pm   #5
JUSTDAMO
Festoons - that's the one!!!
Thanks evryone
Old 30th Jan 2020, 11:00 pm   #6
TowerRadio
They were also used in illuminated bell pushes,various voltages I seem to remember.Les
TowerRadio is offline   Reply With Quote
Old 30th Jan 2020, 11:17 pm   #7
broadgage
Yes, festoon bulbs. These come in a vast selection of ratings and dimensions.
Careful measurements should reveal something suitable in size.
Various voltages are available but 12 volts is the most common. If using an LED bulb, then it will probably need a DC supply. For an incandescent bulb, AC or DC is fine.
Do double check the inside of the unit, just in case it already contains a light source, and the fuse holder is intended to contain a fuse to protect the supply to the light.
broadgage is offline   Reply With Quote
Old 31st Jan 2020, 12:41 am   #8
Refugee
Refugee's Avatar
I have got an alcohol free branded beer pump laying about that I used to use for parties with normal lager when I could get the stuff in kegs.
It has a bit of 2 core cable at the base but I have never tried the lamp.
I may be able to dig it out and have a look if you want.
I think there used to be a low voltage transformer under the bar for them.
Refugee is offline   Reply With Quote
Old 31st Jan 2020, 1:23 am   #9
AC/HL
AC/HL's Avatar
The genuine ones used to use 24v filament bulbs fed from isolation transformer(s). You can use any (low) voltage in a domestic setting.
Bill, BVWS member
Old 31st Jan 2020, 2:01 am   #10
Silicon
If you do an internet search for Marantz bulbs you will probably find the 8Volt fuse shaped (approximately 6 x 30mm) bulbs.
6.3Volt versions are also available.
Silicon is offline   Reply With Quote
Old 31st Jan 2020, 2:10 am   #11
joebog1
joebog1's Avatar
We call them fuse lamps. They come in 6.3 volts, 8 volts and 12 volts.
They are the same size as a 3AG fuse, i.e. 6.35mm X 32 mm.
Joe
joebog1 is offline   Reply With Quote
Old 31st Jan 2020, 11:01 am   #12
mike_newcomb
Hi Justdamo.
those type of Bulbs / Lamps are used in Entryphone Bell-push Panels, which are generally on 24/7.
As others have advised they come in various sizes (some very close), voltages and wattages. Also supply might be ac or dc.
Have found incorrect Automotive Festoon Bulbs fitted, which while bright can run too hot, especially as on 24/7.
With that fitting double check the size, especially the diameter needed, as there are two sizes very close.
Regards - Mike
mike_newcomb is offline   Reply With Quote
Old 31st Jan 2020, 11:03 am   #13
McMurdo
McMurdo's Avatar
My dad collects beer pumps, amongst his serial hording issues. His are all supplied with 24V AC and a few of them have come attached to what looks like bell transformers, usually multi-output. Might be worth keeping yours at 24V in case you get others (?) which already have lamps in there. 24V will use less current too.
https://shop.atlantic.org.uk/bar-lig...rmer-216-p.asp
Kevin
McMurdo is offline   Reply With Quote
Old 31st Jan 2020, 5:19 pm   #14
Joe
That's an inch and a quarter by quarter fuse in old money
Old 31st Jan 2020, 9:46 pm   #15
hannahs radios
They had similar to those in my relative's pub, the bulbs were the fuse types and rated for 24 volts working. I think for the seven or so pumps there were two transformers which lived under the bar. The plastic housing just got barely warm even after being on from 5 PM to around 10 PM.
Hope this helps.
hannahs radios is offline   Reply With Quote
