Old 1st Oct 2021, 8:21 am   #21
M0AFJ, Tim
M0AFJ, Tim's Avatar
Default Re: AM on 80m - Much Happening?
For the last 6 months I’ve been suffering with intense QRN right across 80 60 and 40M making QSO’s very difficult, recently Western Power have been doing some work and bingo, noise disappeared so I’ve been on AM a bit on 80 and 60M, really good signals recently in the mornings on 3615 and as we go into winter it will be worth calling anytime during the day.
Modern SDR based rigs produce very good AM, I have a IC7610 and always get good reports although it’s not as good fun as a vintage rig.. (Anyone got a KW Vanguard or DX100 for sale?).
If you run AM on 60M watch your bandwidth.
If you want a sked PM me.
Tim M0AFJ
Helston Cornwall
M0AFJ, Tim is offline
Old 1st Oct 2021, 10:04 am   #22
Sinewave
Sinewave's Avatar
It's still going on, or something is on the same frequency and mode.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline
Old 1st Oct 2021, 6:25 pm   #23
G6Tanuki
G6Tanuki's Avatar
There's also quite a bit of late-afternoon AM operation on 3615: so far today as part of my "Five-a-Day" HF QSO-target I've worked a station near Birmingham, one north of Swansea and one in Ireland.
All using around 10 Watts from my 1970s-vintage military PRC320 into a 100-foot-longwire. Its rather-aggressive VOGAD speech-processing (courtesy of Plessey's IC development team in Swindon) is rather good at getting through the noise.
You need to be in the right place at the right time - as dusk falls and the 'gray line' moves in from the East you start to get more and more Continental SSB stations coming up out of the noise.
This is where a 'selective sideband' receiver can help: put the incoming AM through a SSB filter to lop-off one sideband and some of the carrier; then reintroduce the carrier at high-level from a local oscillator and demodulate the result as SSB. Though purists would say you need the local carriier to be phase-locked to the vestiges of the transmitted carrier, in practice a solid local carrier will swamp the transmitted carrier and you then 'tune for the lowest growl'.
G6Tanuki is offline
Old 1st Oct 2021, 6:34 pm   #24
Aub
Aub's Avatar
The main AM activity will be tomorrow morning on the VMARS net. It starts at 0830 but there is always a pre-net gathering from anytime after 0600, depending on conditions.
Aub G4KQL and VMARS member
Life's a long song, but the tune ends too soon for us all.
Aub is online now
Old 1st Oct 2021, 7:57 pm   #25
Aub
Aub's Avatar
Should like to add that any licenced person is welcome to join the net, you don't have to be a VMARS member, as long as you use AM from whatever rig you like.
Aub
Aub is online now
Old 2nd Oct 2021, 3:39 pm   #26
Sinewave
Sinewave's Avatar
Listened again this morning, yesterday appeared to have stronger stations. I will join in one of these days, but for now I may have to drop my vertical as it's getting an absolute battering from the high winds, I need some additional guys. I'll probably pull the long wire back up and see how that goes.
Sinewave is offline
Old 2nd Oct 2021, 3:56 pm   #27
Station X
Station X's Avatar
Plent of activity there this morning, but most stations are buried in S9+ noise at my location.
Guess I need a magnetic loop aerial
Graham. Forum Moderator
Station X is online now
Old 2nd Oct 2021, 4:36 pm   #28
G6Tanuki
G6Tanuki's Avatar
A longwire is what I'm using - it's not that high up - indeed height can be unhelpful. For good intra-UK working you are often better off with a wire only 10 or 20 feet up, so you get plenty of ground-reflection - have a look at "NVIS" antennas [sometimes nicknamed cloudwarmers].
G6Tanuki is offline
Old 2nd Oct 2021, 4:44 pm   #29
Station X
Station X's Avatar
I'm using a 150Ft long wire at 20ft height running North-South.
Could put up a half wave dipole, but I expect the noise level would be similar.
Old 2nd Oct 2021, 5:18 pm   #30
G6Tanuki
G6Tanuki's Avatar
Your longwire sounds like it should be good on Tx.
For Rx you could even try a ferret rod; in the past I've used ferrite rods on 160 and 80M and their directivity is useful for nulling-out noise if the source is in a determinable direction.
Alternatively you could look at having a separate 'noise' antenna arranged to pix up as much noise as possible, then phase it against the main receive antenna to null out the noise - a quick search of "Jones noise balancer" will reveal how the US air-force did this on WWII bombers to null-out the interference from the spark-plugs of multiple Wright Cyclone engines!
G6Tanuki is offline
Old 2nd Oct 2021, 9:06 pm   #31
roadster541
There were 19 stations logged for the first AM-ARS net on 19th Sept. I first called in early in the net and was acknowledged, using an Elizabethan XMTR, designed by G5RV in 1955. I had a series of lighting problems in the shack so rigged up a "portable" XMTR in the house and managed a couple of contacts just before the net closed down.
The next one is 19th October at 19.30 local time, 3.625MHz: a much more civilised time of day than early morning!
73
Rod
M0LXY
roadster541 is offline
Old 3rd Oct 2021, 1:12 pm   #32
Panrock
Panrock's Avatar
There used to be a NBTV net on 80 metres. Just the job if you had a MUTR Televisor to view the 32-line pictures.
Steve
https://www.radiocraft.co.uk
Panrock is offline
