Old 8th Feb 2018, 6:55 pm   #1
TonyGrim
TonyGrim's Avatar
Default Fuse identification?
Hi all,
Wondering if anyone has seen this fuse type before, and where I can find a supplier. Dimensions are 12mmW, 9mmH, 7mmD. Lead pitch is around 7.5mm.
My research on the internet has not found anything like it. Unobtainium?
BTW please excuse the crap photo.
TG
TonyGrim is offline
Old 8th Feb 2018, 8:21 pm   #2
Graham G3ZVT
Graham G3ZVT's Avatar
Default Re: Fuse identification?
does it have to be exactly the same? I would put a round Wickmann fuse in of suitable rating.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 8th Feb 2018, 9:12 pm   #3
TonyGrim
TonyGrim's Avatar
I'm reluctant to do that. It's used in the high-voltage DC section of an SMPS, immediately prior to the PWM / switching FETs and it's characteristics are therefore quite important.
TG
TonyGrim is offline
Old 8th Feb 2018, 9:23 pm   #4
Nickthedentist
Nickthedentist's Avatar
Google image searching provides a pic of some almost identical ones, described as:
DC400V 6.3A BD63 DIP2 fuse
Nick.
Nickthedentist is offline
Old 8th Feb 2018, 9:55 pm   #5
Ancient Geek
It's a Daito BD63. This link will tell you the characteristics:
http://images.100y.com.tw/pdf_file/BD50.pdf
Steve
Ancient Geek is offline
Old 8th Feb 2018, 10:25 pm   #6
TonyGrim
TonyGrim's Avatar
Nick.
Genius!! Thank you my friend
That took a couple of days ...
TG
TonyGrim is offline
Old 9th Feb 2018, 9:40 am   #7
Nickthedentist
I think you meant to thank Steve!
