Old 6th Feb 2018, 9:10 pm   #1
Wendymott
Wendymott's Avatar
Default Rigol DSA815 Spectrum Analyser
Hi Peeps.
Has anyone any idea how to Switch on the SWR measurement function. I have the Umpteen digit Code.............. but I have no idea how to apply it.
I will be eternally grateful.
Should get out more.
Regards
Wendy G8BZY
Wendymott is offline
Old 7th Feb 2018, 3:24 pm   #2
MrBungle
MrBungle's Avatar
Default Re: Rigol DSA815 Spectrum Analyser
Gah I hate doing this on Rigol products. Same across all of them. Press the System button. There should be a License or Option Info section in there. Might be in the System Info menu. You will have to poke around and find it. It's not in the same place as in the manual on my DS1054Z and DG1022Z. There's an install button after that. Then you have to enter the code on the main encoder which is horridly difficult.
Google "Riglol" if you don't fancy paying for the rest of the options. That supports the DSA815.
MrBungle is offline
Old 7th Feb 2018, 5:39 pm   #3
Wendymott
Wendymott's Avatar
Hi Mr Bungle..... Tried that and no joy.... Sent an email to Rigol... let you know the outcome.
Regards
Wendy G8BZY
Old 7th Feb 2018, 5:50 pm   #4
MrBungle
MrBungle's Avatar
Good luck. I had one issue and they got back to me within 24 hours.
MrBungle is offline
