Old 15th Sep 2023, 10:45 am   #1
mediaseller
Default Solid State 9 2 Wave Band - Satellite Electronics LTD
Hi.
I am restoring one of these currently, and can't find a circuit diagram anywhere.
I've tried www.service-data.com and radio museum.
Can anyone help, please?
Thanks in anticipation.
ID:	285005   Click image for larger version
mediaseller is offline
Old 15th Sep 2023, 10:59 am   #2
paulsherwin
paulsherwin's Avatar
Default Re: Solid State 9 2 Wave Band - Satellite Electronics LTD
It looks like a pretty typical late 60s Hong Kong no-name radio. I doubt if you'll find service data for it, but it's likely to be a standard conservative superhet design. The audio output stage is clearly transformer coupled.
I actually think it looks quite attractive in a cheap 'n' cheerful sort of way.
paulsherwin is online now
Old 15th Sep 2023, 11:25 am   #3
Graham G3ZVT
Graham G3ZVT's Avatar
Further to Paul's reply, the schematic won't be a million miles different from this typical 6 PNP transistor, -9 volt supply rail, Far Eastern, 1960s set.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 15th Sep 2023, 11:58 am   #4
paulsherwin
The OP's set looks as if it may use silicon NPN transistors with a +ve supply rail - easy enough to work out anyway. It's post 1967 and pre 1978, probably around 1970.
Old 15th Sep 2023, 1:56 pm   #5
mediaseller
Hi.
Thanks. Yes, they are silicon pudding bowl transistors.
Old 15th Sep 2023, 1:57 pm   #6
mediaseller
Thanks Graham.
Old 15th Sep 2023, 1:59 pm   #7
mediaseller
Thanks, Paul.
The variable capacitor is a bit scratchy, so I cleaned the spindle end. I'll try it out again tonight.
Old 15th Sep 2023, 2:00 pm   #8
mediaseller
Thumbs up Re: Solid State 9 2 Wave Band - Satellite Electronics LTD
Thanks for the drawing, Graham.
Old 15th Sep 2023, 5:10 pm   #9
Graham G3ZVT
R.M. says Number of Transistors = 9. The power of suggestion.
Graham.
G3ZVT
Old 15th Sep 2023, 5:45 pm   #10
paulsherwin
It may be using transistors as diodes to bump up the transistor count, a very common HK dodge in the 60s. Sometimes manufacturers just lied though.
Old 15th Sep 2023, 5:53 pm   #11
G6Tanuki
G6Tanuki's Avatar
Yes, a transistor with B and C strapped together to work as the detector, and another similarly wired in the Base bias network of the output transistors....
Always good to bump up the transistor boast count.
At least a diode wired transistor in the output stage bias network was a serious attempt, properly done it could reduce the overall standing current in the output pair and compensate for ageing batteries where the voltage was sagging.
I can hear an Owl.
G6Tanuki is online now
Old 18th Sep 2023, 8:33 pm   #12
mediaseller
Thanks all for your suggestions.
I was at least successful in the end with the help of some responders.
Replaced the tantalum cap with a parallel pair to get the right value. I went over the board, resoldering poor joints, and used contact cleaner on the VC.
After a quick basic alignment, it works well.
Thanks again.
Old 20th Sep 2023, 10:39 am   #13
Herald1360
Herald1360's Avatar
An interesting mix of TO72, plastic and TO5(39?) transistors if nothing else!
I wonder if the solder bridge between the IF cans was a design feature or a quick fix production bodge?
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 20th Sep 2023, 12:03 pm   #14
paulsherwin
A lot of HK radios from that era used TO5/39 output transistors despite their large size, often covered with coloured plastic.
Old 21st Sep 2023, 10:16 am   #15
Hybrid tellies
Hybrid tellies's Avatar
I am glad you got this radio working. Its a very attractive looking radio and a good example of what was a very popular style of small HK radio from the late 1960's.
I agree with all the comments said about the transistor count using transistors with a leg snipped as diodes typically for the detector and output bias.
Simon
BVWS member
Hybrid tellies is offline
