Old 10th Sep 2023, 4:47 pm   #1
Andy G4NPA
Default Wiring materials - any asbestos hazard- pre war Murphy
Hello all
Can't find any specific advice - is the "cloth" covered wiring in an A70C likely to contain asbestos. If so any recommendations for dealing with it ?
Thanks
Andy
Andy G4NPA is offline
Old 11th Sep 2023, 5:34 pm   #2
Katar83
Default Re: Wiring materials - any asbestos hazard- pre war Murphy
I've not seen any signs of asbestos anywhere in my A40C, I doubt they used it in these sets and if you find any frayed crumbling wires, just desolder(bag and bin) and replace.
Katar83 is offline
Old 11th Sep 2023, 7:17 pm   #3
PaulR
PaulR's Avatar
From research my son has done following buying a Victorian house almost everything made before the mid 1990s might contain asbestos - Artex for example. However the amount released in disturbing cloth covered wiring is likely to be minimal - if it contains any at all
Paul
PaulR is offline
Old 16th Sep 2023, 1:09 am   #4
Oldmadham
In a radio, there would have been no benefit in using asbestos, which is messy as hell in woven form.
In a lot of cloth covered wires, the insulation was actually rubber, (or sometimes varnish) with the cloth simply an outside sheath.
Oldmadham is offline
Old 16th Sep 2023, 11:23 am   #5
PJL
Use of asbestos in a domestic environment is mostly post WWII till the 1980's. We spent a load of money having it removed from our early Edwardian house that had been owned by a school from the early 1950's. They had asbestos board installed in the basement where the central heating boiler was and in a partition wall added to the upper hall.
Asbestos found in radios is mostly confined to dropper cables used during and post WWII to convert US radios to 230V and shielding around mains droppers such as the DAC90 but also on many others.
PJL is offline
Old 17th Sep 2023, 5:09 pm   #6
Ken Taylor
Ken Taylor's Avatar
Bakelite may contain asbestos, I'm not sure if that is relevant to your set. It is probably not dangerous if the Bakelite is unbroken and in good condition, but it was brown asbestos they used - the worst kind.
Ken Taylor is offline
Old 28th Sep 2023, 7:54 pm   #7
Andy G4NPA
Thanks everyone for the feedback, greatly appreciated.
There isn't much Bakelite in the set as far as I can see - apart from the knobs of course. No big dropper resistors as it's a transformer set it has a metal screen above the rectifier to protect the cabinet - nothing untoward there.
As far as the wiring is concerned, the cloth covering is indeed covering a rubber inner that seems OK for the most part but is crumbling at the ends in places.
