Old 14th Aug 2023, 8:35 pm   #1
mancunian69
mancunian69's Avatar
Default Ferranti 125 resto
Guys,
I'm currently restoring a 125 and it's in really bad shape, but I refuse to senf it to landfill.
I picked this set up locally. It was listed on eBay as a 99p starting auction. I asked the seller how much he wanted for it. To my astonishment, he said I could have it for free. FREE, I love that word.
I collected the set. The guy, in his 50's told me that it belonged to his mum and had been in the family for years. When restored, I am going to send him some images of it up and running again after donkeys years in the loft.
The cab was falling apart and so far, I have done all necessary repairs and now started to refurbish it, but more on that later.
Now, I am startting to restore the chassis. I downloded a schematic and am a bit confused.
The dial light on the chassis I have uses a pigmy type bulb. It is rated at 1.2W 240V
The schematic I have states that it should be a 6.3v bulb.
I have looked on eBay for pigmy bulbs, but all I can find are the types for ovens/microwaves with a much higher wattage. 10W+
I'm stumped here. Any suggestions?
Rgds
Michael.
mancunian69 is offline
Old 14th Aug 2023, 8:46 pm   #2
mancunian69
Default Re: Ferranti 125 resto
FYI
Old 15th Aug 2023, 6:24 am   #3
Kentode
Kentode's Avatar
If the schematic says it should be 6.3v, then it's fed from the heaters. You need to track where the bulb holder in your set is powered from. 240v bulb = fed from the mains.
A previous owner may have altered the circuit...
I've just tried to download the schematic from Radiomuseum but got an error.
Regards, Ken.
BVWS member
Kentode is offline
Old 15th Aug 2023, 7:53 am   #4
John M0GLN
John M0GLN's Avatar
Extract from circuit attached, if it is as original it's supplied by a transformer for the valve heaters, the HT is straight from the mains, as Kentode's post you will have to make sure and also be aware that there is no isolation provided from the live mains potential.
John
Last edited by Station X; 15th Aug 2023 at 8:05 am. Reason: Please don't post circuits from rm here. They can get very upset! Extract from VRSD attached.
John M0GLN is offline
Old 15th Aug 2023, 8:05 am   #5
Paul_RK
Paul_RK's Avatar
As Ken says, the bulb could be an owner modification - does the arrangement look original? There's a clear photo of a 125 with the back off at
https://www.snellingsmuseum.co.uk/ar...o/ferranti-125
which appears to show a typical MES bulbholder in the centre of the dial. Are the markings on the pygmy bulb clear enough for you to be confident in those? I only ask because I've never seen a 1.2W 240V bulb, and its power consumption is actually below that of the 6.3V 0.3A MES bulbs typically used - rightly or wrongly I'd expect its filament to be pretty fragile, but for sure it wouldn't be very bright. A few sets - the Ekco U243 comes to mind - did use pygmy 240V bulbs for scale illumination, but I think in that instance it was 15W, whose light was a tad overpowering... or had a previous owner put in a 15W bulb because he couldn't get hold of anything smaller? Long time since I had that set...
Paul
Paul_RK is online now
Old 15th Aug 2023, 8:21 am   #6
Station X
Station X's Avatar
Just measure the AC voltage across the lampholder.
Graham. Forum Moderator
Station X is online now
Old 15th Aug 2023, 10:25 am   #7
G8UWM-MildMartin
I have a very similar-looking Ferranti 745 that has a pygmy bulb in a BC lampholder.
It's probably worth comparing the circuits.
G8UWM-MildMartin is offline
Old 25th Sep 2023, 6:25 pm   #8
MurphyNut
MurphyNut's Avatar
I'm not so sure, I've just picked up one of these and mine contains a 240v 15W pigmy bulb! I think it's going to look too bright so I'll put a low wattage "night light" bulb in it's place. Perhaps there was a modification made on this set by the manufacture, my set looks entirely original and untouched!
Clive
MurphyNut is offline
Old 26th Sep 2023, 4:30 pm   #9
PaulR
PaulR's Avatar
I have a radio which uses a mains voltage dial light. I have replaced it with a low wattage LED lamp. As it remains switched on for hours at a time I think it is an improvement as it remains cool and uses a lot less electricity. Very easily reversed for the purist of course.
Paul
PaulR is offline
Old 26th Sep 2023, 4:48 pm   #10
PaulR
PaulR's Avatar
Regarding the Ferranti, there must have been two versions. This https://www.youtube.com/watch?v=0momdinNOFM shows a mains powered lamp (not the original in this case)
This https://www.snellingsmuseum.co.uk/ar...o/ferranti-125 doesn't have the fitting for a mains lamp
Paul
PaulR is offline
Old 26th Sep 2023, 5:49 pm   #11
Radio Tech
Radio Tech's Avatar
That's what I would do replace it with an LED or if you still prefer a bulb then use a 7V 0.3A MES
Ken
Radio Tech is offline
Old 26th Sep 2023, 6:56 pm   #12
PaulR
PaulR's Avatar
I think the version the OP has uses a mains voltage bulb. One of the amber 2W LED filament type something like this https://www.ebay.co.uk/itm/113910725...r=414189124377 would probably look good
Paul
PaulR is offline
