14th May 2009, 9:35 pm | #1 |
Pye Cw17 Crt
Hi Guys , At the moment i am working on a PYE CW17 restoration but have come to a stop , The crt heater has a short so i need to replace it ( see crt wanted ) the type fitted is a MW 43-80 but have had no luck in obtaining one ,but i do have several AW 43-80 crt`s , would it be possable to use this as an alternative ? if so , what modifications would need to be done ? Thanks Chris .. P.s if anyone has a MW43-80 crt to sell me i would be greatful , Thanks again .
14th May 2009, 10:26 pm | #2 |
Re: Pye Cw17 Crt
Hi Chris.
I'm probably barking up the wrong tree here as I really have no specific knowledge of these tubes but the first one sounds like a magnetically focussed tube and the second an electrostatically focussed tube. (Like the different tubes used in the all-but identical Bush TV56 and TV66.) I guess that, given an extra source of focus-potential voltage, you could happily swap them over. (Removing all the magnetic focussing paraphernalia of course.) I'm not telling you this through any even remote expertise or experience, just thoughts from the top of my head really. (Prepares to be shot dopwn in flames...) Kind regards. From Mike.
G7TRF |
15th May 2009, 9:49 am | #3 |
Re: Pye Cw17 Crt
Hello Chris,
Mike is spot on here. The AW43-80 will replace the MW43-80 easily. The gun assembly is the same other than the addition of a focus electrode. You will need to remove the focus magnet assembly and if my memory is correct this also includes the picture centering shuffle plates. The AW43-80 should focus with the focus pin earthed. Its not at all critical and if very slightly out of focus may need to be connected to H.T. A usual supply is available around the tube base. You will require a picture centering device. This looks like a massive ion trap magnet and fits just behind the scan coils. Any one will be suitable providing it is for a 70 or 90 degree electrostatic focus tube. Something I have not tried is to simply slip the AW tube into the set and see if the focus magnets will focus the beam. It may well do so after you have adjusted the ion trap of course. Hope this helps. Regards, John. |
15th May 2009, 2:00 pm | #4 |
Re: Pye Cw17 Crt
Hi Guy`s , Thanks for the info, I will try the AW 43-80 as it is first to see what happens & i will let you know if it works , Ceers , Chris.
15th May 2009, 7:38 pm | #5 |
Re: Pye Cw17 Crt
Hi Chris, As an experiment I replaced an MW43-64 with an AW43-80Z in a Philips 1756U many many years ago and it gave quite acceptable results ISTR, even with no connection to the focus pin or centering magnets. Also the fact that the replacement was a 90 degree not 70 degree I dont remeber any problems with underscan either.
John C |
16th May 2009, 5:30 pm | #6 |
Re: Pye Cw17 Crt
Hi Guy`s, The CRT transplant worked o.k. ! I had to remove the old focus unit & add a 2meg preset from the boost line to chassis for the focus potential . I did try with the old focus unit but the AW 43-80 has a slightly shorter neck than the MW43-80 so no room for the ion trap. Anyway the sets working ok at last , Cheers , Chris..
16th May 2009, 7:57 pm | #7 |
Re: Pye Cw17 Crt
Is that the "designer pye set " from the mid 50s ? Tube loooking good
16th May 2009, 11:59 pm | #8 | |
Re: Pye Cw17 Crt
The AW43-80Z uses the gun assembly from the 110 degree AW43-88. No ion trap required The CW17 was one the range of Pye products called the "contemporary" series. The cabinet stylist was Robin Day. He was not the TV broadcaster. DFWB. |
