7th Oct 2008, 11:59 am | #21 |
Re: Contest to find oldest television
Interesting notion DR W. Broadcast on SW? so [theoretically] might have been possible although I'd guess not a lot of K watts! Dave W
7th Oct 2008, 12:12 pm | #22 |
I'm sure that I have read that 30-line transmissions could be received all over the country, and Baird also transmitted to ships and the like. I seem to remember when 30-line transmisions ended Baird is recorded as saying something like people all over the country will have sets which they cannot use, and also commented that the VHF system only had a small coverage whereas the 30-line system was national.
It would be easy for someone in Scotland with a 30-line Televisor and a standards converter to display modern day transmissions on it. It will be interesting to see what happens. |
7th Oct 2008, 12:13 pm | #23 |
Much as it would be nice to set the competition organisers a problem and get a free standards convertor I don't think it's possible within the rules. Only working 625 line UHF sets can be entered.
So what was the earliest dual standard set? I believe some so called dual standard sets only had a switch to change the line speed and lacked a UHF tuner.
7th Oct 2008, 12:19 pm | #24 |
I don't think the rules state or even imply this.
Peter |
7th Oct 2008, 12:28 pm | #25 | |
7th Oct 2008, 12:35 pm | #26 |
"Only televisions that can demonstrably receive and display current television broadcasts are eligible" I was about to agree with the Doctor [as Drs are always right] and there is no mention of 625/405 or even 30 lines that I can see. However..... if current broadcasts means colour [not really clear] it would need to be 625 wouldn't it? I can see this subject running as long as The
Mousetrap. Dave W We crossed so just seeing your last post Graham, I wonder if "demonstrably" means then able to receive current [prior to switch over] analogue colour signals without even venturing into digital reception ie is there any yet? This is all about switchover as far as I can deduce. Last edited by dave walsh; 7th Oct 2008 at 12:41 pm. |
7th Oct 2008, 12:40 pm | #27 |
Well if it has to be colour then it would have to be 1967, unless of course someone uses a 405 NTSC colour set, but from the way hey have worded it then i woul presume if a 30-line televisor was displaying currenmt transmissions then they would have no choice but to acknowledge it. Current broadcasts can be received in colour or black and white, it all depends on the receiver and the way it displays the signal being received.
7th Oct 2008, 12:40 pm | #28 |
Current broadcasts means UHF 625 line black and white or colour. After all you can still buy a black and white TV Licence. Strictly current broadcasts would include all forms of digital TV, but equipment receiving these broadcasts wouldn't need converting.
I suspect that UK Digital roped in ILB to publicise the contest without telling him the rules. Hence his references to pre war sets in the attic.
7th Oct 2008, 12:44 pm | #29 |
Although the publicity as announced by Iain Logie Baird does stress that ideally it would be something as old as 1936.
Perhaps the publicity and the rules are out of sync? Assuming that a demonstrably working 1936 set (or older) is entered, it must obviously be currently running via a standards converter and UHF input. That being so, a digital set-top box with RF output, upstream of the converter, would be all that Digital UK would need to do to complete the conversion. |
7th Oct 2008, 12:46 pm | #30 | |
7th Oct 2008, 12:48 pm | #31 |
kalee20 beat me to it. UK Digital will get a lot of publicity from this competition for very little outlay on the prize. ie a Freeview Box with UHF RF output.
7th Oct 2008, 12:51 pm | #32 |
Who's going to explain all this to Digital UK? Dave
7th Oct 2008, 12:58 pm | #33 |
It seems to me that what's needed is an old VCR, which of course receives analogue TV signals, with its SCART output fed to an Aurora Standards Convertor. You could then feed the Aurora's output to any working TV set you liked so long as the Aurora could handle that standard. If the set turned out to be the oldest you'd win a free Freeview box and get lots of publicity.
Are any Scottish members of the forum intending to enter anything like this?
7th Oct 2008, 1:07 pm | #34 | |
I did email them this on the 3rd of Oct. I have a 1937 HMV901 in working order. see http://uk.youtube.com/watch?v=7nRZ85OWr-8 Although this is showing recorded material it is perfectly capable of receiving normal broadcasts via a standards converter. Peter Scott As yet I've received no reply. Peter |
7th Oct 2008, 1:26 pm | #35 |
Good question re Scottish members Graham but what's eligible? Perhaps 1952 is a red herring after all [appropriate to the East Coast].
The rules state "Scotland' oldest working television". Not that they actually had to be in use in Scotland at the time of manufacture! A [Scottish] lawyer might argue that any television-as long as it's been Resident in Scotland-from any era and working to any standard [whether or not appropriate signals were available at the time] should qualify. UK Digital would argue " We were only trying to make a point about he more contemporary but older type sets still in use" for the Digital Switchover". The Judge might well conclude "that's as maybe but your rules aren't clear enough". This could then open the back door to say a 1936 ish set that someone's had running over the border for some time..taking us back to Ian L B's original radio comment. Maybe he's looking for a set approximating to the year JLB was broadcastingown in London that has since migrated. I take your point Peter but unless your set has been a Scottish resident... it can't enter! Dave W Last edited by dave walsh; 7th Oct 2008 at 1:35 pm. Reason: more legal points |
7th Oct 2008, 1:38 pm | #36 |
I bet the organisers weren't expecting this can of worms. They were probably just hoping for some old granny with a well-kept KT3 or TX9
7th Oct 2008, 1:38 pm | #37 | |
Peter |
7th Oct 2008, 1:53 pm | #38 | ||
There's a get out clause in the rules too:- Quote:
7th Oct 2008, 1:59 pm | #39 |
Hi Graham,
I strongly suspect that you are correct. There are certainly several Baird Televisors in Scotland that are in working order and given the involvement of Iain Baird surely the best outcome would be a demonstration of one of those attached to a digibox. If I were Iain Baird I certainly wouldn't want a product of the Marconi/EMI company to win (again). Peter |
7th Oct 2008, 2:13 pm | #40 |
Apologies to Peter for some daft reason I had you mixed you up with the other TV expert The Doctor, who is nowhere near Edinburgh.
I must be getting over-excited ! On a lawyers opinion you could be a very strong contender! I would give it another go at UK Digital-you are certainly a good publicity prospect for them as well. In my experience a well chosen postcard or strategic letter reaches parts e-mails don't even get close to. Your local paper is another option. They will probaly be happy to pursue it for you. Maybe I'll contact Ian LB re all this. I was involved in the protest about knocking down JLB's last residence here in Bexhill recently and e-mailed his dad Malcolm at one point but didn't get a response from Canada [although MLB wrote to the local paper]. Then ILB turns up in Bradford over the hill from Rammy! Dave W Last edited by dave walsh; 7th Oct 2008 at 2:23 pm. |
