8th Feb 2019, 12:33 pm | #1 |
Vidor CN359
A good friend of mine saved this radio from going to the tip and has done a lovely job of re finishing the cabinet.
He asked me if I could look at the chassis as it didn`t work very well. well I offered to take it away and repair it for free as been as it was just about working. Well after changing the usual wax caps , electrolytic,s and an o/c 100k resistor , I found the tone control was o/c. On removing the tone pot ( which was not the original ) I noticed that there was a burn mark on the chassis where the original tone pot had burnt out. Now this pot is 50k with a .05uf cap on the wiper and usually a tone pot has a higher resistance than this. Now unfortunately my bvws trader sheet cd which would probably have this information on is cracked and will not play so I am hoping some kind person can confirm the correct value of this pot and possible capacitor. The sound o/p valve is unusual in being a 6AG6 . Robin |
8th Feb 2019, 12:49 pm | #2 |
Re: vidor cn359
Pot is a 50k cap is .05 (.047uf)needs to be high voltage.
John |
9th Feb 2019, 10:09 am | #3 |
Re: Vidor CN359
Thank you john that's a great help.
Can anyone confirm the 6AG6 valve is correct ? Robin |
9th Feb 2019, 10:19 am | #4 |
Re: Vidor CN359
Look here: https://www.radiomuseum.org/r/vidor_cn359.html
According to the above, originally it would have been an EL33. A 6AG6 (or KT61) is a sensible replacement. Alan
Never Leave Well Enough Alone... |
9th Feb 2019, 2:47 pm | #5 |
Re: Vidor CN359
As John has previously remarked, a capacitor in that position should be rated at 1Kv I would suggest.
Thermionic Emission, warms the cockles of your tubes. |
