Old 7th Sep 2008, 11:46 pm   #1
johnmarshmanagain
johnmarshmanagain's Avatar
Default Sync Insertion
There's a host of problems assoc with the home made converter, not least its (my) poor ability to mix the sync pulses into the picture info coming off the Op Amp which takes the o/p of the DAC.
Is there a sensible way to do this without the two video and the sync fighting seeming to fight each other ? It does work sometimes, but is sensitive to picture content.
The general idea of the attached dodgy circuit in use is that when the sync pulse comes along, it fires the trannie which shorts the video to ground, in effect. My problems may in reality relate to coupling and black level clamping, ofcourse…..
If there’s a better cct I could copy I’d be pleased to see it !
Pip pip JM
johnmarshmanagain is offline
Old 8th Sep 2008, 8:13 am   #2
ppppenguin
ppppenguin's Avatar
Default Re: Sync Insertion
Not sure where to start here. 100u coupling caps what I presume to be a 75 ohm video path are going to damage the signal very badly. The transistor can pull down to give a reasonable falling edge of sync but the rising edge is going to be abysmal. Add in the effects of AC coupling and I realy don't want to predict what the waveform will look like. If you want to amuse us, how about a photo of the waveform.
The simplest approach is just a resistive mixing network. Not 100% ideal but let's assume you've got about 1.5Vp-p of video from the opamp and 5V of syncs from logic. Try around 560R from the sync source to the output and 82R from the video opamp tothe output. This will give you about 1Vp-p of video with about 300mV sync into a 75 ohm load. There will be a DC offset but this shouldn't matter if black level is below about 1V DC. Sync edges will be too steep but again this won't matter for simple experiments.
Best method of all is to add the syncs digitally and use the DAC to convert the whole waveform.
ppppenguin is offline
Old 8th Sep 2008, 8:23 am   #3
Duke_Nukem
Duke_Nukem's Avatar
Brute force isn't the way. What you really need is a switch.
Attached is a basic circuit (sorry, monday morning and haven't finished cuppa yet).
Bias base volts so that "no video" gives 30% of your output signal. Pulse base high to turn it off -> 0v at collector = sync.
Video source needs to be low impeadance and you need to watch what you drive the tranny with (volts need to be stable outside of sync period so watch out if AC coupling.
Also, it is a common base configuration so that'll help keep the bandwidth up (though watch out for coupling of sync pulse into collector circuit, don't switch it too fast).
AC coupling the input isn't good as there is no black level. However the cct attached is just to give example of using tranny as a switch.
TTFN,
Jon
TTFN,
Jon
Duke_Nukem is offline
Old 8th Sep 2008, 8:27 am   #4
oldeurope
oldeurope's Avatar
Smile Re: Sync Insertion
Hi, you can find some solutions in the MK II converter:
https://www.vintage-radio.net/forum/...ead.php?t=1757
The 625 line sync is eliminated at the input.
The new 405 sync ist added at the output.
I tested two different ways:
https://www.vintage-radio.net/forum/...3&d=1108233028
sync constant current added to the non clamped vision signal (Q24), DC restorer (Q29)
https://www.vintage-radio.net/forum/...7&d=1119087114
vision clamped on blanc level (Q36) sync add (Q39)
The MK III converter replaces only the V-sync.
https://www.vintage-radio.net/forum/...?t=7795&page=3
https://www.vintage-radio.net/forum/...5&d=1150622399
Kind regards,
Darius
oldeurope is offline
Old 8th Sep 2008, 8:40 am   #5
ppppenguin
ppppenguin's Avatar
Why bother to switch when you can add? Switching requires that black levels are matched. If the video is correctly blanked, sync can simply be added, either at the DAC output or at the final output. If the video isn't correctly blanked, then do that digitally before the DAC. If the sync waveform is mucky then clean it up with a dedicated HCMOS gate before adding it to the video.
Jon's circuit would need an output buffer unless the collector resistor is 75 ohms.
Old 8th Sep 2008, 10:03 am   #6
johnmarshmanagain
Chaps
Blimey ! Plenty to think about there.
Many thanks for the sketches and web links
More anon....
John
Old 8th Sep 2008, 10:57 am   #7
oldeurope
oldeurope's Avatar
...sync add (Q29) sorry.
Old 11th Sep 2008, 5:09 pm   #8
oldeurope
oldeurope's Avatar
Hello,
the UVB can do this job too.
Kind regards,
Darius
