15th Jul 2021, 5:15 pm | #21 | |
Re: Philips V5A
15th Jul 2021, 6:57 pm | #22 |
Re: Philips V5A
Pictures of Bob's V5A. That Mazda UU4 has to go, can't have that make of valve in a Philips set! Got to be a Philips type 1821 or the Mullard equivalent.
DFWB. |
15th Jul 2021, 7:45 pm | #23 |
Re: Philips V5A
Hi David wonder if the original smoothing capacitor has been changed because it took out the original rectifier valve kind regards Bob
15th Jul 2021, 8:09 pm | #24 |
Re: Philips V5A
"Hi David wonder if the original smoothing capacitor has been changed because it took out the original rectifier valve kind regards Bob"
Hi Bob, That's possible or the wet electrolytics had gone low capacity and all that was available at the time of the repair was those TCC capacitors. Likewise for the Mazda valve. The UU4 is indirectly heated which is much better than the original directly heated 1821 valve. My V5A has a Mullard IW4-350 rectifier. Close up picture of the original Philips wet electrolytic capacitors. DFWB. |
16th Jul 2021, 10:40 am | #25 |
Re: Philips V5A
Hi David have to find some smoothing capacitors and the get rid of that Mazda valve kind regards Bob
16th Jul 2021, 11:30 am | #26 |
Re: Philips V5A
If you contact the person who very kindly supplied my 1821 (search my thread) I believe they said that they had two
Gabriel |
16th Jul 2021, 8:16 pm | #27 |
Re: Philips V5A
Hi Gabriel thanks thanks for telling me about the person who had 2 1821 valves i have pm them let you know the outcome kind regards Bob
16th Jul 2021, 9:18 pm | #28 |
Re: Philips V5A
Hi Gabriel thanks kindly to you forum member greg simons has kindly helped me out with a Philips 1821 valve for the Philips V5A radio kind regards Bob
17th Jul 2021, 8:24 pm | #29 |
Re: Philips V5A
The dimensions of the Philips HT capacitors are: 63mm high and 39mm diameter.
Found one old capacitor which will be modified to fit in the V5. See attachment. Now on the lookout for another capacitor of the same type. DFWB. |
17th Jul 2021, 9:07 pm | #30 |
Re: Philips V5A
Hi David that looks a lot better than the TCC capacitor in my set fingers crossed that another one can be found and both of the TCC capacitors can be removed kind regards Bob
19th Jul 2021, 11:02 pm | #31 |
Re: Philips V5A
Hi Bob,
cut that old capacitor to size to fit in the V5A. Capacity is 30 microfarads. DFWB. |
19th Jul 2021, 11:22 pm | #32 |
Re: Philips V5A
Hi David you have done a great job is there any writing to identify this capacitor to see if another one can be found kind regards Bob
19th Jul 2021, 11:56 pm | #33 |
Re: Philips V5A
Hi Bob,
it was an 8microfarad 500 volt dry electrolytic. There might be another similar capacitor somewhere in the shop. Got plenty of the type that requires a capacitor clip. DFWB. |
20th Jul 2021, 12:19 am | #34 |
Re: Philips V5A
Hi David if there is not another similar capacitor use the one that requires a clip until a similar one can be found just looked in side my set some one a long time a go put a capacitor clip on top of the ht transformer then decided not use it but to tack in that TCC capacitor in kind regards Bob
20th Jul 2021, 4:31 am | #35 |
Re: Philips V5A
Hi, I have a v7a made for the New Zealand market that I have restored.
You will need close to 10 meters! of replacement wiring as I found when I rewired mine. |
20th Jul 2021, 10:46 am | #36 |
Location: London, UK. Bury, Lancashire quite regularly :)
Re: Philips V5A
This might prove useful for the crumbling yellow rubber insulation.....
(Philips seem to have had a penchant for this colour.) https://www.hilltop-products.co.uk/s...ng-yellow.html
Thermionic Emission, warms the cockles of your tubes. |
20th Jul 2021, 1:58 pm | #37 |
Re: Philips V5A
Hi Clipper65 looks like i under estimated the amount of cable i need what other work did you do on your V7A ? please could you post some pictures of you V7A . Hi Nanozeugma thanks for the link
20th Jul 2021, 11:31 pm | #38 |
Re: Philips V5A
Yes I had totally underestimated the amount of wire needed and had to order more to finish, all I needed to do to mine was replace all the wax and electrolytic caps and a good clean and polish (the set was totally original when I purchased it). I need to obtain a suitable grill cloth in order to finish the set. I also had to replace the output valve managing to find a nos valve at a good price. I'm away on holiday for the next 3 weeks but will post some pics on my return. I found some sutible pale yellow wire on aliexpress wich I used, just order 10 meters though 9
21st Jul 2021, 2:07 pm | #39 |
Re: Philips V5A
Thanks Clipper65 looking forward in seeing your pictures enjoy your holidays kind regards Bob
23rd Jul 2021, 9:22 pm | #40 |
Re: Philips V5A
The HT capacitors are ready to be fitted in the receiver.
DFWB. |
