20th May 2019, 4:45 pm | #1 |
Working Simon SP4 - next steps?
Hi All,
New the forum, hope everyone is well! I have a Simon SP4 left to me by my father. It's in mostly working order but is unrestored apart from replacement of the rubber chassis anti-vibration mounts with some silicone pads. The transport works in both directions. Occasionally the take-up spool momentarily stops, probably due to flats in the drive rollers. This usually cures itself after a few minutes of running. Sound is OK, decently loud but muffled. Could be head alignment, but could also be drifting caps or similar. Some of the pots are crackly. There's no significant hum in the output. I feel like it should be receiving at bit of TLC at it's time of life, but where would be a good place to start? I have a reasonable amount of experience in general electronics, access to equipment and also to a 3D printer. Any insight appreciated! James |
20th May 2019, 7:15 pm | #2 |
Re: Working Simon SP4 - next steps?
Because of the age of the machine, there will be several capacitors which should be replaced irrespectively of how they check out, you should also check and replace resistors that are out of tolerance.
20th May 2019, 9:35 pm | #3 |
Thanks Michael. Anything particular urgent due to safety issues?
21st May 2019, 7:54 am | #4 |
paper Wax capacitors and Hunts moldseal capacitors for starters.
