Old 12th Nov 2019, 7:25 pm   #1
mickm3for
Default BC-454 Command rx/tx
Hi any one know the size of screws to hold outer covers on the command series rx/tx. a few are missing, I have 4 out of around 60 thanks in advance Mick
mickm3for is offline
Old 12th Nov 2019, 7:29 pm   #2
Hans PE1KWH
Default Re: bc 454 command rx/tx
Those are pretty hard to find. You best look for a donor unit.
Hans PE1KWH is offline
Old 12th Nov 2019, 8:45 pm   #3
g4aaw pete
g4aaw pete's Avatar
Hello Mick
can you post a picture, and if you have a micrometer, measure the thread diameter?
Regards
Pete
g4aaw pete is offline
Old 12th Nov 2019, 8:59 pm   #4
Default Re: BC-454 Command rx/tx
We (work) are about to scrap a load of BA screws, I can win a few if you like.
Old 12th Nov 2019, 9:02 pm   #5
G4XWDJim
G4XWDJim's Avatar
Search this forum as follows and another thread will appear with all the details you need.
‘What are the screws in the "Command Set" ARC-5’
Jim
G4XWDJim is offline
Old 12th Nov 2019, 9:11 pm   #6
JHGibson
They are 3/48
John.
JHGibson is offline
Old 12th Nov 2019, 9:13 pm   #7
JHGibson
make that 3-48
John
JHGibson is offline
Old 12th Nov 2019, 9:17 pm   #8
Ed_Dinning
Not one of the more normal US "fine threads for attachment purposes", but you may be able to find then within the adverts in Model Engineer, or Model Engineers Workshop.
Ed
Ed_Dinning is offline
Old 12th Nov 2019, 9:46 pm   #9
JHGibson
The 3-48 screws in my ARC5 receiver are of a style known as a binder head. They are 3/16 long and all have a internal star washer under them.
John.
JHGibson is offline
Old 13th Nov 2019, 4:51 pm   #10
ex seismic
If you find a source please let the rest of us know.
ex seismic is offline
Old 13th Nov 2019, 4:57 pm   #11
M0FYA Andy
This is the place which is usually recommended on the US forums to supply suitable screws - https://www.mcmaster.com/ - unfortunately they will not deal with non-US addresses.
Andy
M0FYA Andy is offline
Old 13th Nov 2019, 5:39 pm   #12
WB6NVH-GEOFF
Amazon lists 3-48 screws as do a number of web vendors, which is where I got some, however the original brass style with black oxide coating and lockwasher seems to be unobtainium.
WB6NVH-GEOFF is offline
Old 13th Nov 2019, 9:02 pm   #13
dodgy-dxer
dodgy-dxer's Avatar
I picked up some US thread screws when last in the US
Home Depot and Lowes and even Walmart had some
Try and find someone going over or coming over here. I dont get there very often or would offer
Seems 3-48 are used on a Gibson guitar and can be found on eBay UK, maybe too long though?
Or just type "3-48 screws in UK " into Google
Fred
dodgy-dxer is offline
Old 13th Nov 2019, 10:48 pm   #14
M0FYA Andy
I think the difficulty can be finding the correct type with 'binder' or 'binding' heads - wider and flatter than most heads. Ordinary round or cheese heads just aren't right, and I'm not sure will fit in the mounting rack.
Andy
Old 16th Nov 2019, 2:03 am   #15
FrankB
Tacoma Screw products in Tacoma Washington, USA should have 3-48 screws in stock.
http://www.tacomascrew.com/
Tacoma Screw Products, Inc.
2001 Center St Tacoma Washington USA
(253) 572-3444
I have dealt with them for over 30 years now. Good folks there.
Likely you will not find the screws with black heads or the attached lock washer, but they have surprised me on what they have several times.
Typically the screws come in a container of 50 or 100. They will break containers and sell you just a few also.
Their main store is about 70-80 miles from me.
FrankB is offline
Old 16th Nov 2019, 6:10 pm   #16
JHGibson
Google:
Machine screws 3-48 x 3/16 slotted binding headstainless steel
Look at Amazon.
John.
JHGibson is offline
Old 16th Nov 2019, 7:37 pm   #17
mickm3for
Hi thanks for your ideas just found some from a friend in Canada, a box of 200 of them so have spares Mick
