31st Oct 2019, 10:38 pm | #1 |
Microwave Modules 70cms to 28MHz converter
Does anyone know the spec of the 101 MHz xtal
in the 70cms to 28MHz converter? Kevin |
1st Nov 2019, 9:38 am | #2 |
Re: Microwave Modules 70cms to 28MHz converter
theres a manual for the transverter here.
http://oz1bxm.dk/manuals/MicrowaveMo...ter-432-28.pdf They are usually 20 or 30pf capacitance but you’d need to know whether its a fundamental or 3rd overtone |
1st Nov 2019, 11:09 am | #3 |
That's an interesting oscillator. THough the crystal appears to be in parallel across the transistor base to ground, the transistor is actually used as a common base amplifier and the crystal works as a bizarre narrow-band decoupling capacitor for the base. So it is a series-mode crystal. It will be either third or more probably 5th overtone mode. Either will do.
As far as loading capacitance goes, there isn't any. You want true unloaded series mode to get the frequency dead accurate. It won't be badly off at other load values. Overtone crystals are devils to pull or adjust. Pullability (parts per million) scales down by the square of the overtone number. David
2nd Nov 2019, 2:17 pm | #4 |
I think it's 5th overtone, series resonant.
Kevin |
